Old 02-22-2012, 11:41 PM   #1
Michael Star
Mr. Reliable
Ok, I just recently traded my 99 Subaru DD for a 70 GMC with a 350, factory air, and a TH350.
Did a bunch of routine stuff and tracked down some electrical issues, and most important, added a new fuel cap which took care of the gas smell inside the cab. Added a manual choke cable as the PO didn't have it hooked up. Luckily for me, he did add an internal regulated alternator, and HEI dist. I've got the trim pieces that finish off the front. I also added new grounds to the stock locations, but used pieces of audio cable I left over. 4 gauge grounds aren't overkill, are they?
My plans are just to make it a reliable DD and maybe lower it a bit. Nothing crazy, but something fun.
Not the original color...
Bad Compressor that I will need to replace
Parts time!
Original ground and hot leads?
Motor with new air filter. You couldn't see light through the old one. There is an Edlebrock 1405 carb with a Weiand intake manifold on it
Glad I have a heated garage to work on it.
Hella 500FF driving lights with yellow protective vinyl covers. Not sure if I like the foglight placement. I used the front plate holes.
Michael Star is offline   Reply With Quote
Old 02-25-2012, 08:59 AM   #2
Michael Star
Re: Mr. Reliable
Old 03-25-2012, 04:11 PM   #3
Michael Star
Re: Mr. Reliable
Picked up a set of late model 17" wheels for cheap. Also got a set of 1" spacers, but now I am thinking I should have gone with 2"
Old 03-25-2012, 04:23 PM   #4
Tinkermc
Re: Mr. Reliable
if you keep hanging around here your truck could become expensive. It does look like a nice place to start.
Tinkermc is offline   Reply With Quote
Old 03-25-2012, 05:26 PM   #5
Michael Star
Re: Mr. Reliable
tell me about it! Ive figured the costs so far and I have only about $360 into it. There is a lot more I want to do
