Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 03-18-2012, 12:42 AM   #1
vegas80step
vegas80step's Avatar
Dusted off the old tools... (Sub box build) 1980 stepper
So I priced a few places for a sub box behind my seat.. got a $1000 bid and a few $800's
Might be fair, but more than I was gonna pay.. So the old tools got dusted off..
This is my first (so take it easy, master box builders.. lol...) sub box build and behind these seats are kinda of a pain...
But I had help...
I cut 4 dividers and wanted to make sure the were all the same, so I sanded them at one time to make sure they were all even..
It's hard to tell but I added a second piece of wood in side the amp rack at an angle up to fill the void and point the Amp up a little..
I still have to fiberglass a frame for the corners, I want to fill the rounded edges and add my 6x9's...
Then I'm going to fiberglass the whole front, try and get it to mold to the truck.. then paint...
I've only touched fiberglass once before so will see how it goes.. lol..
side note: took about 4 hours. Used a table saw, miter saw, sander, router (first time using it.. real cool tool) and a nail gun..
I went a little over board and went for two 12's... they call for .5 - 1 of air.. these ended at .63 I'll throw in some poly-fill and hope for the best...
I didn't recess the subs, One I had enough room not to and I was trying to get every bit of air space I could..
I'll post some more when I get time to finish...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 03-18-2012, 01:44 AM   #2
joe231
joe231's Avatar
Re: Dusted off the old tools... (Sub box build) 1980 stepper
Looks good!!
CHEVY ONLY
Old 03-18-2012, 05:59 AM   #3
Pop's C-10
Pop's C-10's Avatar
Nice
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 03-18-2012, 10:27 AM   #4
survivingalone
wow.....looks good.
survivingalone is offline   Reply With Quote
Old 03-18-2012, 12:48 PM   #5
vegas80step
Thanks fellas.. here is the test fit...
Maybe I should have test fit it before this point?? lol... no risk, no reward...
Old 03-18-2012, 01:43 PM   #6
Zebb
Zebb's Avatar
How do you plan on attaching the box to the cab? Or are you going to just let it sit there?
Zebb is offline   Reply With Quote
Old 03-18-2012, 01:53 PM   #7
vegas80step
I think it will stay put the door rubber holds it in place pretty well.. Just in case of a hard stop I'm going to throw a screw threw the botton (the screw will sink into the floor) of the amp rack before I mount the amp.. it will stop it from popping out... and will be hidden by the amp...
Old 03-18-2012, 03:04 PM   #8
54Caddy
GM Addicted
54Caddy's Avatar
nice box almsot similar to mine. My box is held in with compression. I put two angles 6x9 boxes next to it and you have to squeeze it all together its hard to pull the box forward will get you some pictures maybe you can do the same
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 03-19-2012, 12:51 AM   #9
vegas80step
Here is today's update... I tried a few different ways to get the corners framed.. most sucked and didn't work.. ended up going with a kerf cut...
I forgot to take a picture of it in the truck after the test fit... I might go back out and start on the placement of the 6x9's if not tomorrow...
Old 03-19-2012, 01:09 AM   #10
bowtiemanchevyman
bowtiemanchevyman's Avatar
you might want to use something stronger i use a cragebolt for mine.
and what are your messurements for your box
bowtiemanchevyman is offline   Reply With Quote
Old 03-19-2012, 01:13 AM   #11
bowtiemanchevyman
i love the way you are using ever inch back there. Im rebuilding mine and ive been tring to figure out what to do with the corners. and still be able to get mine out easy
Old 03-19-2012, 12:58 PM   #12
vegas80step
This thing is pinched in there pretty good i don't think it will every fall out... I don't have the messurements.. I kinda cut as I went..
Thanks..
you can get it out but you need to work at it a little, but like you said it was the only way I could come up with to use all the space. I don't like to be able to see the empty sides...
Old 03-19-2012, 03:23 PM   #13
vegas80step
Time for some fiberglass... will see how it goes...
Old 03-19-2012, 05:45 PM   #14
bowtiemanchevyman
what are u using fleece for the first layer.
Old 03-19-2012, 06:08 PM   #15
vegas80step
That's a super fancy, high priced, extra nice...... old T-shirt... lol
Old 03-19-2012, 08:35 PM   #16
vegas80step
A few layers of glass... Still not 100% on what I'm doing... but I"ll wing it..
Old 03-20-2012, 12:20 PM   #17
vegas80step
holly crap it's taking for ever to dry... pretty cold in my garage...
I'm sure it would take 3 seconds out here in the summer when it's 140 in there...
Old 03-21-2012, 12:04 AM   #18
jimmydean
jimmydean's Avatar
Looking very nice!
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-22-2012, 01:49 PM   #19
shortyred
Man that's nice!!!
shortyred is offline   Reply With Quote
Old 03-22-2012, 03:57 PM   #20
vegas80step
thanks guys...
time for bondo... will see how this goes... lol..
Old 03-22-2012, 10:21 PM   #21
vegas80step
I went with a bondo/resin mix... I was able to brush it on... well see what I end up with after sanding...
Definitely going to need more filler.. I still have some low spots...
Old 03-22-2012, 10:45 PM   #22
bowtiemanchevyman
what was your mixture u use you know 80/20 90/10 i like the end result
Old 03-23-2012, 12:00 AM   #23
vegas80step
I mixed the resin in until it was thin enough to spread with a brush.. I'd say 60% bondo 40% resin... I really hopping I used enough hardener, it's still a little tacky, it's only been a little over an hour and half and it's a little cool in my garage.. I'll throw it out in the sun in the morning...
One tip, I mixed it a little wet.. then started on the flat and top parts.. once the mix started to set up a little I started on the face and lower parts...
Old 03-23-2012, 01:50 AM   #24
bowtiemanchevyman
thanks
Old 03-23-2012, 05:00 PM   #25
vegas80step
sanded it down.... took forever..........
then I went with just Bondo...
looks like more sanding fun.......
