Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 03-24-2012, 11:49 AM   #1
tll74
"Junkyard Dog"
tll74's Avatar
Parting out 72 Suburban C10 402 TH400
Parting out 72 Suburban 402, TH400, aftermarket AC, 3.07 rear, and upper-lower tail gate. Also have a 72 K10 350 AT and a 72 C10 350 AT to part out after this one so many parts are duplicated. The 402 P/S pump assy, Alt brackets, and motor mounts are already sold. All parts are plus shipping. Payment by MO or check. Please reply in the thread. Thanks, Tom
"I'll take...." puts your name on it. Once total cost and or Q's answered is posted please respond with in 24 hours. After that is goes to second in line. If it's a pass please post so. Thanks
402 engine...needs rebuilt, runs ok but rings are bad. Priced as pictured less carb, dist, exhaust, valve covers, oil line, flywheel, temp senders, and other trinkets. All original never been apart. 400.00
TH400 also original never been apart. nice fluid clean in the pan. Not road tested but works fine to move around. 250.00
3.07 open coil spring rear end. looks nice inside. 250.00
Aftermarket AC specifically for our trucks with 402 brackets. Was not charged and untested. Pump turns nice and pulley is quiet and smooth. Complete less the condenser. 150.00
5 lug disc conversion: spindles, steering linkage, calipers (rebuilt), hard lines, dust shields, lower control arms, and rotors if wanted. Will need new upper ball joints. 225.00
Upper molding kit. VERY NICE, some oxidation as all have. Every mounting clip good and with the 4 original screws. Will not separate. 200.00
Rear side interior panels. see pics, cardboard warped. 50.00
Spare cover, cardboard bad. 15.00
Spare wing nut and retainer (dipped and media blasted) 12.50
Soft Ray M75 tinted glass. RH rear door glass has short deep scratch and RH front has typical vertical scratches otherwise very nice. Wings are glass only. 240.00 for all. Will separate.
Std firewall heater box with replaced rust free (dipped) tins. Nice color. 45.00
High hump with no holes tunnel cover. 50.00
Parchment visors. nice but not perfect. 22.50 each or 40.00 pair
72 only door panel foam seals fronts and RH rear. Nice 5.00 each
TH400-TH350 trans x-member (hot tanked). 25.00
71-72 turn lens. One has chip one nice. 5.00 and 10.00
71-72 turn lens housing. 10.00 each
RH armrest needs painted. 12.00
LH outside door handle. Very nice driver. 25.00
RH outside door handles. Both pitted. 7.50 each
69-72 black horn button. Very nice. 20.00
RH lower molding sub only. Between RR door and wheel opening. Very minor small ding. 10.00
LH front fender nice needs repainted. 12.00
LH fender rear molding. Minor ding. 8.00
RH fender rear molding. Minor ding. 8.00
Window cranks and inner door handles 2.00 each.
402 starter heat shield. Solenoid mounting tab is split. 25.00
Wiper motor. looks very nice. 17.50
71-72 gas pedal assy with TH400 switch and wiring to engine harness. 40.00
Outside rear view mirrors with original screws. Original and VERY NICE. I had the RH glass replaced at local glass shop. 75.00
Sub spare tire wheel tub. Some rust. 52.00
Parchment seat belts. LH re tractor is lazy, pitted male buckles, NICE covers. 52.00
Wiper arms with original blades. 12.50 each
Deluxe stainless door panel trim. RH and LH. Pair 25.00
Coil spring trailing arms. Hot tanked and acid dipped. No dings or dents Very nice. Ready for paint. 175.00
Interior headliner bows. Chrome in decent condition. 10.00 each
Bench seat tracks. Nice knob and in nice condition. 25.00
Dash cut for radio hole replacement. 15.00
Rear tail lamp housings 7.50 each
Rear tail lamp lens. Both bright one nice and one has crack in center. 12.50 and 5.00.
Reverse light housings. 5.00 each
Reverse lens. bright 6.00
LH rear side panel upper chrome trim. was a little rusty been acid dipped and rust free. Has pits. 9.00
RH rear door latch catch. Dipped and media blasted. 7.50
Rear side interior trim panel mounting hardware complete. 45.00
Lower gate latches and rods. 29.00
Lower gate support straps. 12.00 each 20.00 pair
Lower gate inner latch mech (key cylinder and button mounts to this)
Key cylinder and button assy with key. 18.00
key cylinder outer bezel has scuff with gasket. 6.00
upper gate outside handle. pitted 11.00
upper gate center latch. 12.50
upper gate supports. 38.00 pair
upper-lower gate latch striker plates. Three of them 5.00 each
4 little stops for lower gate. 8.00
Fuel tank straps. 25.00
Chevrolet emblem broke between the H and E nice chrome. 8.00
cover plates 5 of them 10.00
Upper horizontal window felts 2 short and one long. nice condition considering 8.00 each
Rear door vertical window felts with out frame (front of glass) 10.00 each
Rear door vertical window frames RH and LH, felt bad. 12.00 each
RH rear door lock linkage. 12.50
RH rear sill plate. looks very nice was rusty on botton side I have dipped this and now rust free. 22.00
Under dash wiring Very nice. 65.00
Back glass rubber (no bead). nice no cracks. 22.00
71-72 Grill very nice. no cracks or damage. Repainted in correct color. 125.00
Upper control arms. Hot tanked. 25.00 each
Windsheild rubber with stainless steel moldings. nice rubber and moldings. 65.00
Extra set of w/s moldings only. 40.00
Dipped and media blasted parts. Ready for paint and refinishing of your choice.
RH and LH rear window regulators. Rollers are stuck. 20.00 each
RH rear door hindges. 29.00
RH front door hinges. 35.00
Upper gate hinges. needs bushings. 8.00 each
lower gate hinges. needs bushings. 8.00 each
RH door latches. Like new. 30.00 each
LH door latch. Like new. 35.00
RH front door sub only stricker plate. 7.00
RH rear door or pu front stricker plate with back bracket. 12.50
LH door stricker plate. 7.00
RH door vertical felt channel. 12.00
LH rear vertical felt channel. 12.00
E-brake ratchet assy. like new. 35.00
Spare tire wing nut and retaining plate. 20.00
Wiper transmissions. 25.00 pair
Vent pull rods with detent and clips. Rh or LH. 5.00 each
Core support-fender triangle. 7.00
TH400 e-brake guides mounts to trans cross member. 4.00 each 7.50 pair
Dual exhaust hangers complete as pictured. 110.00
Rear coil springs. 40.00
Front springs (402 truck) 40.00 on hold may keep
Carrier bearing support bracket. 10.00
Track bar typical bushings. 22.00
C10 coil spring u-bolts nice threads. 15.00 pair
U-bolt - shock plates. 20.00 pair
3 core rad mounts with rubbers. 25.00
Hood latch 69-72 chevy. 22.50
Steering intermediate shaft. 25.00
Steering gear rag joint. 15.00
71-72 Charcol canister bracket. 17.00
402 RH exhaust shield. 25.00
402 crank and water pump pullyes. 50.00
RH inner door handle mounts. 5.00 each
TH400 complete shift linkage. 45.00
Coil spring over loads complete. 75.00
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 03-24-2012, 11:53 AM   #2
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
Re: Parting out 72 Suburban C10 402 TH400
Do you have the stove pipe and tube.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 03-24-2012, 12:45 PM   #3
budnikguy
budnikguy's Avatar
VERY interested in all locks and keys, ignition, doors, and rear hatch if they function.. please. What is the plan for the body/tub?
budnikguy is offline   Reply With Quote
Old 03-24-2012, 12:50 PM   #4
budnikguy
budnikguy's Avatar
may be interested in more...pending pics....
Old 03-24-2012, 12:51 PM   #5
4xshort
4xshort's Avatar
I would like some parts from your k10 thats coming up, AT shift lincage, high hump trans cover, fan shroud, engine dip stick, rear frame crossmember and drivers side frame horn Thanks Josh
1971 Chevy shortbox 4x4 made in Canada
4xshort is offline   Reply With Quote
Old 03-24-2012, 01:12 PM   #6
tll74
"Junkyard Dog"
tll74's Avatar
pics
Old 03-24-2012, 01:17 PM   #7
tll74
"Junkyard Dog"
tll74's Avatar
more pics
Old 03-24-2012, 01:24 PM   #8
tll74
"Junkyard Dog"
tll74's Avatar
more pics
Old 03-24-2012, 01:31 PM   #9
tll74
"Junkyard Dog"
tll74's Avatar
pics
Old 03-24-2012, 01:37 PM   #10
tll74
"Junkyard Dog"
tll74's Avatar
just more pics
Old 03-24-2012, 01:43 PM   #11
tll74
"Junkyard Dog"
tll74's Avatar
a few more
Old 03-24-2012, 01:49 PM   #12
tll74
"Junkyard Dog"
tll74's Avatar
more pics
Old 03-24-2012, 01:51 PM   #13
So.Cal.Chevy
I'll take the seat belts and white visors pending cost +shipping 92595
So.Cal.Chevy is offline   Reply With Quote
Old 03-24-2012, 01:52 PM   #14
So.Cal.Chevy
Also interested in rear hatch Brackets that hold up the the top hatch if in good working order. shipped to 92595
Old 03-24-2012, 01:53 PM   #15
tll74
"Junkyard Dog"
tll74's Avatar
getting closer, more pics
Old 03-24-2012, 01:58 PM   #16
tll74
"Junkyard Dog"
tll74's Avatar
almost done!
Old 03-24-2012, 02:06 PM   #17
tll74
"Junkyard Dog"
tll74's Avatar
last of the pics finally!
Old 03-24-2012, 02:11 PM   #18
budnikguy
budnikguy's Avatar
Definitely a buyer for locks (doors, ignition, and hatch)...and edge guards for all 3 doors! Very interested in discussing the body/tub, could you please PM me so we could discuss. Thanks
Adam
Old 03-24-2012, 02:22 PM   #19
rockc
Will take rear LH and RH inside panel trim.
And spare tire retainer nut, bolt and plate
Shipped to 82210
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 03-24-2012, 02:32 PM   #20
Flint70step
Flint70step's Avatar
Very interested in the lower gate itself.It is the exact same faded color as mine and mine is dented badly.I already have all the hardware and emblem so I just need the gate itself.can I get a price on the gate shipped to Texas 78734 please.Thanks
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way)
72 Custom Deluxe Burb(Arizona truck)Nice interior
Great patina
Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668
Flint70step is offline   Reply With Quote
Old 03-24-2012, 02:37 PM   #21
4xshort
4xshort's Avatar
Interested in horn button, radio patch, windshield washer pump and tilt column Thanks Josh
Old 03-24-2012, 03:26 PM   #22
tll74
"Junkyard Dog"
tll74's Avatar
Gary, I have the stove only. I need to get it off and check condition. Will do and price. It will be next week.
Adam, If I have a Ign and door set matched from another truck, I will sell it all. I planned on using this set for my 72 Super. I'll check. The tub is history. I hauled to scrap. It was rusted out everywhere and full of bondo. Plus I had no room to store it.
Josh, 50.00 on the 4x4 shift linkage, perfect fan shroud 100.00 (expensive to ship), 50.00 on cover with t-case shift hole, will check the dipstick, are you looking for the the one with the brace?, 40.00 on the cross member, and how far back on the frame cut? Buy it all we'll do a package deal.
92.00 on parts and 15.00 shipping
Shipped to 82210
Only have the wing nut and plate. May have the nut in the other two. I'll check. I will get shipping cost.
Sorry the gate is also history. It was rusted out so I scrapped it.
Tilt column has already been sold. I have another on in the second 72 C10 yet to part. I'll look it over and report back late Sunday.
Old 03-24-2012, 06:15 PM   #23
mosesburb
I had a V-8
mosesburb's Avatar
How much for all of the lower trim to 85053??
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 03-24-2012, 06:40 PM   #24
So.Cal.Chevy
After giving it some thought, i will pass on the parts i stated. Thanks you though.
Old 03-24-2012, 07:29 PM   #25
capev86
That's a bummer that another special edition Suburban bites the dust. My dad had almost the same truck back in the 80's (small block and cab lights were the only difference).
Parts I definitely want:
Tripod Mirrors
Upper gate supports
All 4 tailgate hinges
Dual exhaust hanger set
Also curious about the seat upholstery and headliner....
capev86 is offline   Reply With Quote
