Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > 99+ Chevy and GMC Parts Board
Closed Thread
Old 04-11-2012, 10:18 PM   #1
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
4L80-E big boy trans 99 Express
was rebuilt appox. 60,000 miles ago and that is a really high estimate. Will warranty it.
$650 shipped CONUS
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline
Old 04-13-2012, 10:20 PM   #2
HeavyMetalChevy
Just a Member
Re: 4L80-E big boy trans 99 Express
ttt
TH400(3rd)
Old 04-20-2012, 11:26 PM   #3
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 05-03-2012, 06:51 PM   #4
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 06-10-2012, 06:10 PM   #5
lucifer
lucifer's Avatar
What engine was it behind??
65 burb On the road Mar 26th Finally
lucifer is offline
Old 06-12-2012, 05:53 PM   #6
HeavyMetalChevy
Just a Member
It was behind 1999 5.7 Vortec. I can get some numbers if interested.
TH400(3rd)
Old 06-13-2012, 07:14 AM   #7
lucifer
lucifer's Avatar
Cool Re: 4L80-E big boy trans 99 Express
I was hoping it was off an LS style engine. Thanks for getting back to me,
regards
lucifer is offline
Old 07-24-2012, 10:16 AM   #8
drtydog
do you still have it? do you know if it will fit one a 8.1?
drtydog is offline
Old 07-24-2012, 04:43 PM   #9
HeavyMetalChevy
Just a Member
Hey you are close!!!! I will check
TH400(3rd)
Old 07-24-2012, 04:52 PM   #10
HeavyMetalChevy
Just a Member
Is this possible? In other words, if I take an 8.1L power plant with it's PCM and swap it into an older 3/4 ton Suburban that originally came with a 4L80E, can that 8.1L PCM control the older 4L80E? Or will I need to swap something out in the transmission?
It depends. If the 8.1L had a 4L80E behind, obviously yes. If the PCM had an Allison, but has the same OS number as a tune that had a 4L80E, then yes, do a segment swap. Also, if the 4L80E has the original style (91-92) internal harness, it will need to be updated. If its an 04+ PCM, will probably need an 04+ force motor in the 4L80E.
From other info I read it should mount right up. A lot of 8.1's had the Allison setup behind it but here:
Here is a list that I condensed down to the 4L80E for Chevy.
AVALANCHE 02-03 4 SP RWD/4X4 V8 8.1L 4L80E
C/K PICK-UP 1500-2500 95-99 4 SP RWD/4X4 V8 5.0L/5.7L/6.0L/7.4L/6.5L DIESEL 4L80E 17 BOLT PAN
C/K PICK-UP 1500 00-03 4 SP RWD/4X4 V8 6.0L 4L80E
C/K PICK-UP 2500 00-03 4 SP RWD/4X4 V8 5.7L/6.0L/7.4L/8.1L/6.5 DIESEL 4L80E
C/K PICK-UP 3500 95-03 4 SP RWD/4X4 V8 5.0L/5.7L/6.0L/7.4L/8.1L/6.5L DIESEL 4L80E 17 BOLT PAN
SUBURBAN 1500-2500 95 4 SP RWD/4X4 V8 7.4L/6.5L DIESEL 4L80E
SUBURBAN 1500 96-99 4 SP RWD/4X4 V8 6.5L DIESEL 4L80E
SUBURBAN 2500 96-03 4 SP RWD/4X4 V8 5.7L/6.0L/7.4L/8.1L/6.5L DIESEL 4L80E
TAHOE/YUKON 95-03 4 SP RWD/4X4 V8 6.0L/8.1L/6.5L DIESEL 4L80E
VAN FULL SIZE 2500 96-03 4 SP RWD V6 4.3L V8 4.8L/5.7L/6.0L/8.1L 6.5L DIESEL 4L80E 17 BOLT PAN
VAN FULL SIZE 3500 95-03 4 SP RWD V6 4.3L V8 4.8L/5.7L/6.0L/7.4L/8.1L/6.5L DIESEL 4L80E 17 BOLT PAN
TH400(3rd)
Old 08-12-2012, 09:50 PM   #11
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Closed Thread
