Old 04-14-2012, 10:51 AM   #1
blazntn
STUPID upper control arm question!
I am finally reassembling my front supsenion after a couple years. I have swapped to the newer 73-87 arms. However, I wondering how I can tell which upper control arm goes on to which side? with out putting everything together twice!!!
thanks
Brad W
blazntn is offline   Reply With Quote
Old 04-15-2012, 04:03 AM   #2
XtechX
XtechX's Avatar
Re: STUPID upper control arm question!
Here's a random thread with good pics to show you how they should look when they're on correctly.
http://67-72chevytrucks.com/vboard/s...d.php?t=502368
Opportunity usually comes disguised....As hard work!!!
XtechX is offline   Reply With Quote
Old 04-15-2012, 09:39 AM   #3
Jonboy
Slots go on anything!
The easiest way to tell is that the shock mount goes towards the rear.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-16-2012, 10:45 AM   #4
chevyrestoguy
chevyrestoguy's Avatar
The shock mount tab is on the lower control arm. You are correct that the shock mount is on the aft side, though.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 04-16-2012, 12:08 PM   #5
Maxxd07
Maxxd07's Avatar
There is a slotted hole for the brake line that goes to the front.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
