Old 03-13-2001, 04:49 PM   #1
clyde
Question steering column swap and other questions
Hello fellow chevy people. I am in the process of doing the power steering/ disc brake swap on my daily driver 66 fleetside. I have an 81 donor truck that came with the factory sticker indicating option codes and have not been able to find a place to download an explanation of them. I am particulary interested in finding out 1. What is a standard rear axle(1GQ1) or where can I find axle code explanation, 2. What is a "special ecomony truck"? (1Z07) (it looks like it has small headers, and has a two barrel). The engine is a 250. Does the old style (PRE 74) head bolt up onto one of these newer engines? Has anyone tried to use a 68 camaro column in the 66? If anyone out there has used the hollow shaft steering shaft (on the 81) instead of cutting and reusing the solid in the 60-66's when doing the power steering swap I would like to hear from you. As I have been driving C-10's for twenty five years I have accumulated lots of parts and may end up selling them after I am done with this latest project. Thanks in advance. clyde
clyde is offline   Reply With Quote
Old 03-14-2001, 07:07 PM   #2
vpersh
vpersh's Avatar
Post
I used an '83 Suburban steering column on my '65. It went in quite easily. I've got it posted on my webpage (maybe you've already seen it) www.geocities.com/vapershing/pickup.html
Van Pershing
Tucson, Arizona
Idea Page
vpersh is offline   Reply With Quote
Old 03-16-2001, 09:46 AM   #3
Troy
Troy's Avatar
Post
Can't help with the other stuff, but I put in a 91 column in my 62 and connected the shaft to the gearbox using a hollow 73-87 connector. Worked GREAT!!!
62 Stepside Streetruck Project
96 Nissan daily driver
Kernersville, NC (Winston-Salem suburb)
84 Sub-beach buggy
76 cj-7 project crawler
05 BMW K1200S
75 Honda CB750
Troy is offline   Reply With Quote
Old 03-17-2001, 12:30 AM   #4
clyde
Talking
Thanks guys... you both have informative sites. Vpersh see your e mail, Troy I had a 63 I loved it unfortunately it was stolen from me at Madi gras in 79 It had a ride that couldn't be beat and although I have owned several (64, 65 and 2 66's) I can not figure out what was so special about the 63! Good luck with your projects!
