Old 05-12-2012, 02:04 PM   #1
deth_1970
deth_1970's Avatar
"Sid Vicious" aka "yeller" My 79 chevy
I bought this truck about a year ago from a friend for $2,000, is was smoking bad out the passenger side exhaust when I bought it, that turned out to be the vacuum modulator,
the truck was mainly stock, it had a low compression, mid 70's emission 350, that was installed by someone prior to my friend getting it,
this is how it looked when I got it
since then I had a blowout doing 70mph down the hwy, it put a nice dent in the drivers side door and took some trim and my emblem with it
then about a month ago my coil went out, thought it might the whole dist so in the process of changing it out, I had a case of "well since I'm here's" I ended up doing this to it
added a single plan strip dominator intake, a set of 305 heads with 1.94/1.5 valves, unshrouded for 2.02's, milled and acid ported, with stainless steel valves
added a cam, a Lunati 40119 solid lifter cam, .
Duration @ .050": 256°-268°, Lift: .550"-.571", Lobe Separation: 106°
which was more than I planned but a Buddy had it laying around and told me to take it,
also had a set of scorpion 1.5 roller rockers that I added
altogether it has 10.5-1 compression (58cc heads plus -13cc to -18cc dished
pistons
estimated hp 450 with 400 tq
planning on installing a 2500 stall, and 3.73 gears
and I have changed the grill, and removed the push bars from the bumper
78 dualy crew cab wife calls "the beast"
79 silverado "yeller"
99 tahoe
02 Gmc sierra
deth_1970 is offline   Reply With Quote
Old 05-19-2012, 08:31 AM   #2
deth_1970
deth_1970's Avatar
Re: "Sid Vicious" aka "yeller" My 79 chevy
the plan for the weekend is to install the headers, get it to move more air out, I figure 2.5" exhaust, long tube headers, and a pair of thrush welded mufflers should do the trick, plus I have been looking around for a Ford 9inch rear end, to make gear changes easier
99 tahoe
02 Gmc sierra
Old 06-16-2012, 01:58 PM   #3
deth_1970
deth_1970's Avatar
got the headers on, bummed tho I bought them used and was told they cam off a truck, only to find out they came off a car, but a little creativity will fix that,
not much else done since getting geared up to get married,
99 tahoe
02 Gmc sierra
Old 09-17-2012, 02:26 PM   #4
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
Looks good...any pics of deleting the smog stuff? I am about to do it myself
Tony
Black Beauty: 85 C-10 SOLD!
Great White: 69 LWB Custom Camper/20 SOLD!
Blue Dragon: 72 K-10 SOLD!
The Tank 77 K-10 KIA
panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for.
I Made The Official So Cal Board Meet
semperfidoordie is offline   Reply With Quote
Old 12-30-2012, 01:17 AM   #5
Squareforceone
Squareforceone's Avatar
updates?
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 12-30-2012, 04:00 AM   #6
bk2life
you named your truck after a 22 yo xxx girl? kinda strange but kinda cool! takes the term get on her!! to a new level!!
howd them headers work? what car did they come off of? ive got chevelle headers for my squarre
bk2life is offline   Reply With Quote
Old 01-29-2014, 12:31 PM   #7
deth_1970
deth_1970's Avatar
well it has been awhile, and real life has gotten in the way of my truck time,
the car headers didn't quit work all that well bought new ones
sid Vicious was also a member of "the sex pistols"
here is what I have done, redid the cam to something more streetable, comp 268, added some Bowtie heads and intake,
the short block was all sock, so it didn't take anytime to discover it's weakness, which was it spinning a rod bearing,
so the new plan is to use the new top end, on a new bottom end, which should hold up,
forged steel crank, lunati rods, and Mahle forged dome pistons, bored .060 over,
planning a 3/4 drop, some suspension work to make her handle better, new paint and a new attitude, be it bad or what,
99 tahoe
02 Gmc sierra
Old 01-30-2014, 02:17 PM   #8
deth_1970
deth_1970's Avatar
so I will go into a little more detail on the new engine build
350 bored .060 over
mahle dome forged pistons with low friction rings
Lunati 6" connecting rods
forged steel crank lightened and balanced
Bowtie phase II heads
Bowtie dual plane intake
268 comp cam
Scorpion 1.5 roller rockers
Demon carb 650 cfm
MSD hei dist
so with all this it should be a solid runner, with good street manners and to be able to pass a car or 2 on the road, and get moderate gas mileage
about 12-1 compression so I will need to upgrade the starter, and run 91+ octane
I know the the cam is on the small side, but is close to the largest cam before I need to change gearing and stall,
after the last 2 attempts of building a motor for my truck, first try resulting in over cammed and valve float, and needing to change stall speed and rear gears,
2nd attempt closer to what I was wanting, ran good had good power lacked compression and resulted in showing what an old worn bottom end does when you push it to hard,
so with my 3rd attempt, alot more thought, more planning and over kill in ways but should do what I want it to, have decent power and still be mild enough to be my DD
99 tahoe
02 Gmc sierra
Old 02-01-2014, 08:51 PM   #9
Hankster
Hankster's Avatar
I cant wait to hear about the third motor set-up finished.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 02-03-2014, 01:37 AM   #10
deth_1970
deth_1970's Avatar
I got the short block together, and it is turning out nice, I will post some pics in the next day or so,
99 tahoe
02 Gmc sierra
