4l60e vs. 4l80e
wanted to get some insight on the two with emphasis on my build.
I am doing a full porterbuilt kit on my 66. And i need to pull the trigger on a motor and tranny quick. My questions are regarding the size of the 4l80E and the modifications i will ned to make to clear the firewall, floor, ect. Along with my planned upgrades to see if i really need it. The plan is a 2007 LY9 (going off top of my head might be wrong) this motor has VVT and is a great motor for gas mileage and a truck motor all in one. I need the truck motor for the accessory drive to mount the alt in the correct place. Plans are just for a good tune, Cam, intake, 3" exhaust for now. But later on once im done hammering the truck around a while i know i will want to go with some type of forced induction. nothing crazy just looking for 400-450 to the wheels. For this HP and Tq range is the 4l80E necessary?? Thanks in advance fellas.. |
Re: 4l60e vs. 4l80e
http://www.porterbuiltfabrication.co...pmember-oh-boy
here is somthing i found with another PB dropmember kit and a 4l80e |
meowMEOWmeowMEOW
Re: 4l60e vs. 4l80e
Even at mid 300's the 4l60e won't live forever, start to push 400 and it better be decently built. Well over 400 and it better be a race built tranny to live for a while. There are plenty running the 4l60e, but its not known to be a hulk.
4l80e's even in close to stock or stock form have very little problem holding 400+, and built they don't really have a limit, just depends on the parts and who built it. (besides, at 700+ nothing lives forever, just gotta pay to play) My 4l80e fit with no modification to the firewall, all that was required was sliding the trans crossmember into the right place and drilling/securing the bolts. I'm not running a dropmember however.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#4 | |
![]() Join Date: Apr 2007
Re: 4l60e vs. 4l80e
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
Re: 4l60e vs. 4l80e
Re: 4l60e vs. 4l80e
Last page has most of the 4l80 issues...more pics when done...........jim
Re: 4l60e vs. 4l80e
4L80 is a beefy trans, in that means it takes power to turn it. So depending on what you plan on doing with the truck you might think about that.
if wanting to cruise/drive it much and MPGs are a concern, you might want to look at the 60. I have the 6.0/80e combo and no matter what (how its driven or how long) it will only get 15MPGs. Not bad really but if I had a 5.3 then I would not put this heavy trans behind it, I would go with a 60e and probably get closer to 20MPGs if set up properly. I have this combo for pulling the car/trailer; and have often thought about pulling it for a 5.3/60e for the MPGs but I know it will not like the TQ loss.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
Re: 4l60e vs. 4l80e
^^^^^ I agree....4l80 is about 50-60 lbs heavier ..more rotating mass..but I will stay with it for now in mine...........jim
Re: 4l60e vs. 4l80e
thinking about forced induction maybe to add more TQ and maybe that would help MPGs too, LMAO
Truck and auto performance nut
Re: 4l60e vs. 4l80e
getting ready to install my 4L85e and looking for input on tricks when you're working off of jack stands vs a lift. I bought a transmission adapter for my jack...but it sets the pan height at about 16"-18" off the floor. This is WAY to high to try to roll it under the truck with the trans strapped to it. I can set the trans/jack to tilt forward or back. I plan on sliding the 200-4r off nose first after I've disconnected it from everything.
So....got any tricks? Not sure I can slide the 85e under the truck and maneuver it up onto my trans/jack ...wondering where all this force is going to come from to lift it up onto the jack, and strap it down...so I can get it into position to bolt in on. Getting too old and weak I guess... ![]()
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: 4l60e vs. 4l80e
Progress....finished clearancing hump.....raised hump 1 inch....clam shelled behind ......sneak preview of what's 2 come......jim
#12 | |
meowMEOWmeowMEOW
Re: 4l60e vs. 4l80e
![]() I've used a furniture dolly to hold my trans (wood square with heavy duty casters) and could MAYBE squeeze it under the truck, with the exhaust out of the way, and jacked WAY up.
#13 |
Re: 4l60e vs. 4l80e
I hate to pull the motor to make the swap...but if I can't figure something out I may have to. For me its all about leveraging whatever tools I can to do the heavy work for me. Got the 200-4r ready to drop...so I'm getting closer
#14 |
meowMEOWmeowMEOW
Re: 4l60e vs. 4l80e
This is REALLY ghetto, but it works. Hook up a jack point to an engine hoist...seriously. If you can do it right (and not flip your truck over lol), you can get CRAZY lift.
#15 |
Re: 4l60e vs. 4l80e
4l60s are problematic after substituting cheap metal in for there sun shell although gm eventually remade it the correct way even though most people just buy an aftermarket heavy duty one regardless, i couldn't tell you how many 4l60's I've seen at my dads shop that are just regular drivers not even abused it has to be at least 2 a week minimum but like a lot of tranny's they can be built to handle a good amount of power
And here's there apparent torque ratings The 4L60-E is rated to handle up to 360 ft·lbf (488 N·m) of torque. The "MT1" 4L80-E is able to handle vehicles up to 8000 lb (3629 kg) GVWR with up to 440 ft·lbf (597 N·m) of torque. The "MN8" 4L85-E is able to handle vehicles from 7200 to 16,500 lb (3265 – 7483 kg) GVWR with up to 460 ft·lbf (624 N·m) of torque. I think you might as well go with the 80-85 to begin with if your gonna beat on that motor and then later add forced induction
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#16 |
Re: 4l60e vs. 4l80e
4L60E's can be built to handle 500 ft.lbs. Without alot of "Race" parts.
Here's the parts list on a 4L60E I had behind a LS1 with a Magnacharger pushing 10psi that made 520hp & 500ft.lbs. at the rear wheels & lived with drag radials,hard lanches,general abuse. Borg Warner 29 element forward sprag 9 Alto "red eagle" 3-4 clutches & kolene steels 5 Alto "red eagle" Forward clutches & kolene steels GM heat treated reaction sunshell Used "seasoned" 2-4 band Hardened pump rings TransGo 4L60E HD2-C shift kit Custom 3000 rpm stall converter w/ anti balloon plate The most important things are....Using a good low mileage core, A good rebuild, & a good converter. I agree with BrewCity.....A "GOOD" stock 4L80E will hold some power. But the stock converter built for a HD truck doesnt work to good on a high perfomance vehicle, Stock 4L80E converters dont like boosted engines either. |
#17 |
Re: 4l60e vs. 4l80e
68 gm custom here is how I put trans on a floor jack by my self under a truck.this might scratch the pan a little though if you don't mind. First I would slide the trans under the truck on the floor. Have it in line with with bell housing facing the back of the motor.remember that bracket holding the torque converter on leave it bolted on so the converter doesn't fall out. Next slide the jack under the truck at the back of the trans as close as you can to the tail housing. Also have the handle of the jack out to one of the sides of the truck. Next your going to lift the back of the tail housing up as high as possible while sliding the jack with the trans adapter under the pan. Next your going to wedge your foot against the side of the jack to keep it from sliding back towards you grab the tail housing and pul as hard as you can and slide the trans up on the jack. I have done many trans install this way by myself and that's with out the trans adapter. Believe it or not the higher you can lift the back of the trans up and the further you can get the jack under the pan it acts like a kids teeter totter as you begin to push down on the back and pull this is pure muscle work so get a second set of hands if you can. Once on the swing the jack handle under the truck so you have room for the handle to move up and down oh yeah give yourself some room between the back of the motor and the front of the trans so you can get as much tilt as you can. This sounds crazy but better than pulling the motor and it works I'll stop babbling now.
Posted via Mobile Device |
#18 |
Re: 4l60e vs. 4l80e
You can also just remove the torque converter to lessen the weight just make sure to properly seat the converter when reinstalling
