Hi guys,
I'm planning to buy a GMC V6 1979. It dose not come with a Air Conditioner, do you guys think that I can install Air Conditioner on it or not?? And it is a 3 speed on tree manual transmission, do you guys think that I can install a floor manual transmission?? Guide me guys PLEASE I'm NEW here... ![]() Thank you Guys
1987 Chevy C20 LWB Stepside 2009 Mercedes-Benz C63 ///AMG 2013 Lexus LX570 Last edited by Chevylongbed; 05-31-2012 at 03:51 AM. |
Re: I need a help!!!
Anything can be done to a truck with enough time and money.
Both of those things can be done. Depends on your skill or budget. There are companies that do the AC thing. Look into vintage air for one. I am not sure about the transmission swap, but I imagine that you just get a manual tranny that works with your engine and cut a hole in your floor. May have to change your steering column too.
79 Blazer 350 TH350 part time 4wd Sold! 86 GMC 1 ton something... |
#3 | |
Regarding the trans question: floor shift is pretty easy. You can buy the appropriate shifter (3 speed or, if you go to a four speed trans then a 4 speed shifter) and cut the hole in the floor. As far as the steering column, you can (a) just leave the bump (b) cut the bump off and mount a nice Sun tach there to cover the hole - ask me how I know that one - or (c) change the column out. It's likely a Saginaw 3 speed, so a Saginaw 4 speed is available through the aftermarket and is a slam dunk installation. Lastly - a '79 6 cylinder would be a straight six (not a V6) unless someone has changed the engine. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Are all transmissions manual/automatic compatible? Can I put a stick on my currently automatic TH350?
Getting Old; Going Broke
Did the truck come with AC from the factory or was it a none AC truck? I would say 90% or more of the people who replace their engine never hook the AC back up for whatever reason.
If the truck had AC, sure you can put a compressor on it (condenser is probably still there) and put the lines back in place and could get it to work for a few $100 and a trip to a mechanic shop that does AC work. If the truck never has had AC, you'll have to go a different route like vintage AC or something.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
Ummm. You can put a floor shifter in if you like, but you'd not have a clutch pedal like a standard transmission would have.
Whoops. Forgot that part.
Here is one way to do your tranny swap:
http://coloradok5.com/auto2manual.shtml
thank you guys so much.. yea sorry my truck straight six engine.. my truck dose not come with AC at all..
1987 Chevy C20 LWB Stepside 2009 Mercedes-Benz C63 ///AMG 2013 Lexus LX570 |
#10 | |
#11 | |
actually I'm looking for a truck hard to find, this is the only one that i found..
like this one ![]()
#13 |
On the hunt for a long bed stepper? Had one on craigslist here about 6 months ago I kept eyeballing, was yellow and white.
#14 |
Wow, nice looking truck!
As was mentioned above, moving the shifter to the floor is not hard. I personally haven't installed an aftermarket A/C, but a lot of hot rodders do it. Good luck! |
#15 |
Thank you guys, I think I will go with Vintage A/C..
Tags |
3 speed, air conditioner, help me |
