Old 06-01-2012, 12:47 AM   #1
bL.A.zer90045
manual roll-up/down windows to power?
Hey there fellas,had some questions pertaining to the swapping out of my manual roll_up/down windows on my 86 k5 for some power windows from a 88 donor? What would I need as far as electrical? From the 88 to make work? Can this be done? Any info/know_how,as usual much appreciated!!!
bL.A.zer90045 is offline   Reply With Quote
Old 06-03-2012, 07:15 PM   #2
blazerkid
blazerkid's Avatar
Re: manual roll-up/down windows to power?
you want the complete wiring harness like every thing.
hope that helps
Alex
blazerkid is offline   Reply With Quote
Old 06-03-2012, 07:32 PM   #3
bL.A.zer90045
Thanks for the response!!! So this is DOable then?
Old 06-03-2012, 08:48 PM   #4
closer9
Yep, very doable. I've got all the parts to do it in my '79, just haven't had the time.
The power window harness should also contain power locks. So, if you find donor doors, pull the lock actuators and linkage as well. Unless you don't want them.
closer9 is offline   Reply With Quote
Old 06-03-2012, 09:04 PM   #5
bL.A.zer90045
COOL!!!! Music to my ears!!! Thanks guys for the feedback,MUCH appreciated!
Old 06-20-2012, 07:14 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
if the truck has power locks and manual wimdows
the wires in the harness plugs are in different spots then with both
and get the rubber boots for the doors/wires
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-20-2012, 11:31 AM   #7
bL.A.zer90045
Thank you for the heads up and great reference pic!!!!
Old 06-20-2012, 12:52 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
No probs lol, it's easier to show it with the fender moved, lol
John
Old 03-15-2015, 08:56 PM   #9
Hankster
Hankster's Avatar
I know I'm digging up an old thread, but how hard is it to add the hole right there for the wires? Thanks all!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 03-17-2015, 11:22 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
I guess the hole would need a "hole saw"for metal,not sure about how that would work
John
