My version of a Hidden Taillight Fuel Filler
After looking at all of the threads on hidden taillight fuel fillers, I decided to create my own version. There's obviously lot of influence from various members and lots of inspiration from this site in general, so thanks to you all!
I've been working on this on and off for a couple of months. Lots of trial and error, but I think all of the tweaking if pretty much finished up and my prototype is working well enough to share. I still need to add the filler/cap fixture, but you can see my basic idea below. I wanted the tail light lens/fixture to move out of the way so that it wouldn't interfere with the gas nozzle and I thought having it retract into the fender would be a cool alternative to having it swing out or up. I used a scrap piece of thin sheet metal that I plan to recreate with something a little thicker now that the design is working well. I did everything with just hand tools and my vise - no welder. It's basically one piece that's been bent into shape and screwed into place. I had to gut the inside of the fender and cut into the inside corner of the bed. I'll build a box to extent the stake pocket to hide this opening. I used RC car tie rods to act as sort of a double hinge. Once I pull everything back out, I'll share some pictures of what exactly I built. Forgive my crude cuts/bodywork/etc. It still needs to be cleaned up some, but I was excited to finally have it up and working and wanted to share. Let me know what you think, and please, if there's a huge potential problem that I'm missing, let me know! Video: http://youtu.be/8C2IuF9wGMI Thanks, Matt
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
Re: My version of a Hidden Taillight Fuel Filler
Looks great.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
I like it.
Here's some pictures of what I built.
![]() ![]() Join Date: Dec 1999
Looks great so far.
Do a step by step of it and post it in the FAQ section here.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
Me too.
In the video it appeared to 'lock' in the down position. Is it just gravity that holds it down or ......
1972 K2500 Long Box 400/350 |
Very cool! If it doesn't latch yet I bet a couple of small neo magnets would hold it in place. Very nice design!
http://smg.photobucket.com/albums/v655/aaronhero/ |
Yeah I wondered the same.
Very neat! I wished I would have done something like this before we painted it!
1971 chevy c10 cheyenne. Bagged. New paint and some other mods. 1999 ford f350 superduty 7.3 powerstroke everything banks 1975 c10 swb "parts runner" <----SOLD NorthWest C10's http://www.facebook.com/#!/groups/Norhtwestc10s/ |
Thanks guys! At the moment it's just gravity holding it in place. I've tried a couple of magnets, but the ones that I "borrowed" from the fridge aren't strong enough. I did put a stopper in place so that the taillight housing won't drop any lower than it should. I drove it around the block a few times and it seemed to stay in place even without a latch/magnet. But the final version will have something to secure it in place.
I'll do a full write up on it when I build the final version and I'll be sure to take a bunch of pictures. Thanks - Matt
great idea! nice job , pics when its finished off, please
needs more $$$
That is definitely cool! Do you think there's enough room to have the lense flip down rather than up?
1970 2wd Blazer |
#13 |
man i wish you could do a pattern of that bottom box bracket...I want to steal this mod...but I do not know if I am that smart...thats some good stuff right there.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
#14 |
When I repaint my 69 I want to do something similar, I won't be using the tail light because I want to leave my tank in the cab, instead I'm going to recess the filler like a newer truck and make a lid that articulates similarly to that one. I want to be able to push on it and have it fold in. I haven't seen one yet, have any of you?
#15 |
that is legit. i wish i had the skills to fab something like that.
#16 |
Thanks again for the great feedback everyone!
I had a little time this weekend to start the fabrication on my final product. I bought a 8x18 sheet of 22 gauge sheet metal at Lowes and got started. First I made a cardboard template that I bent and taped into shape. Once I got the order of the folds/bends figured out, I got started with the sheetmetal. Once I cut out the basic shape, I started to bend it up which went rather quickly. That's about as far as I got. I'll try to wrap it up later this week. There's a lot of trimming that still needs to be done, the piece for the taillight assembly needs fabricated, and the hinges will need to be attached. I'll try to answer some of the questions below: tubbedII - I know there are designs that flip the light down and out. Not sure how you could tuck it in if it came down. Primered 69 - I've started a pattern. Once I know for sure that it will work, I'll post it. AirSpeed - I haven't seen one of our trucks with the mod you're talking about,but I know I've seen something like that somewhere. If I come across it, I'll let you know. FatKid, Elf, etc. - Thanks again for the comments! - Matt
#17 |
needs more $$$
Very clean...do you have the dimensions of the template you used?
1970 2wd Blazer |
#18 |
Old Skool Club
![]() Join Date: Jun 2001
You might check out some of the gas door retainers from the imports, maybe even to the point of getting one that has an inside the cab release. If you used a popper, it would make it pop out a little when you hit the release.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#19 |
i wonder if door rod clips would fit the tie rods you used so they would "clip" into place at the top and bottom of the travel. im assuming the front and back lips that are on the newer template you posted are for something like a bump stop anyway?
1969 mercury cougar XR-7 - sold 1978 Chevy C-10 Scottsdale - sold 1996 chevy k1500 - sold 1970 mercury monterey - sold 1971 chevy c10 4 speed 4x4 - dd ![]() |
#20 |
![]() Join Date: Jul 2010
Man that is trick
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#21 |
After looking at lots of fuel fillers, I selected this one from Whitecap: Whitecap Push Up Angled Deck Fill - 1-1/2" Hose - Gas - 6993A.
The big brown truck delivered it this afternoon so needless to say I ate supper as quick as possible so that I could get it installed. Here's some photos of where things are at this point. For those of you who've asked me for a template, I'll try to measure everything and post one this week. slipkorn - good eye, this version has stops built in but I like your idea about clips. Any idea where to get something like that? The front one is too short and could use to be 1/4" or so taller, but I figured that I could add a small piece of rubber to keep it from rubbing. Now that it's done, I need to take it apart and repaint it. I may also remake it one more time with the taller stop in the front. Feels like this is a never ending project that will be part of a much larger never ending project. I guess that's why it's fun! - Matt
#22 |
One more pic.
#23 |
VA72C10
![]() Join Date: Mar 2008
great job!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#24 |
Sweet!!! Looks awesome
#25 |
Cool Truck
pretty cool
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
Tags |
fuel filler, fuel filler door, hidden, taillight |
