07-13-2012, 12:00 PM | #1 |
Burb spare.
Are these spare tire carriers common on Suburbans??
65 burb On the road Mar 26th Finally |
07-13-2012, 12:14 PM | #2 |
Re: Burb spare.
Lucifer,
My '65 came with an "under the bed" carrier and back third of gas tank notched to clear spare. |
07-13-2012, 12:59 PM | #3 |
Re: Burb spare.
my GMC is under and gas tank is made for it but i have a towing hitchj is in the way preventing use.
07-13-2012, 01:45 PM | #4 |
Re: Burb spare.
I dont own a burb, but Id prefer the in truck spare. Same way I have the fender mounted spare on my 63. Just dont like crawling under them...seems my flats come in the worst weather and least opertune places.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-13-2012, 01:47 PM | #5 |
Re: Burb spare.
My burb has a similar setup.
07-13-2012, 09:06 PM | #6 |
Re: Burb spare.
On my 1965 Burb K-10 4x4 it is under also.
07-14-2012, 02:47 AM | #7 |
Re: Burb spare.
PJT, That's a Sweet Burb.
My 61 came with the spare under the bed as well. You had to crawl under and drop it down off that cross bar-mount(?). My intention was to move it inside, but I didn't want to lose the interior space. I added a tire hoist to mine to eliminate the crossbar support. As 1963c-10 stated; this can cause problems if you get a rear-tire flat back there or in situations where getting to the spare is unsafe. This chain-hoist came off of a 1987 Nissan truck. I may move it back to the interior later.
MusicMan70 1961 GMC Suburban |
07-14-2012, 03:32 AM | #8 |
Re: Burb spare.
Here is the mount on mine, a home made POS that I don't like. Unfortunately they welded it right to the sheet metal. So id I remove it it'll still look crappy.
OP, I like yours much better. I also like the chain hoist idea.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
