Old 07-21-2012, 02:32 PM   #1
RebelChevy
Big block v6 swap
Hey guys, I'm new to the forum! Bing so, I'm not sure this post is even in the right spot but I'll go for it anyways.
I saw a previous thread about a 305 v6 being swapped out for a 305 SBC v8, OP is BigWil. I'm looking into tackling the same project with a 478 big block v6 being removed to put in a 6.5 diesel, but It seems this isn't going to be a bolt in swap. "bigwil" mentioned he was able to fit the new engine right in place with "very minor modification" but never explained how or got any pics posted. So whats the deal? Will the v8 fit in it? And how? What was this minor modification?
AND... I'd love to hear everyone's input on What automatic transmission to sit behind the 6.5 TD in a 35,000 lb bus?
Thanks in advance for fellas!
RebelChevy is offline   Reply With Quote
Old 07-21-2012, 07:47 PM   #2
clinebarger
Re: Big block v6 swap
A 6.5 TD will not live very long in a 35,000 lb. bus, They are a Light Duty Diesel.
Some Diesel engines that are better suited for your bus....
Cummins 8.3 C-series
Caterpillar 3116/3126
International DT466
A Allison MT643 4 speed auto would bolt the any of the above engines
clinebarger is offline   Reply With Quote
Old 07-21-2012, 09:54 PM   #3
Redcap
Junk the 6.5 and find a real engine, as clinebarger stated.
Redcap is offline   Reply With Quote
Old 07-23-2012, 07:43 AM   #4
andrewmp6
What about a 5.9 12 valve cummins?I have seen a few on craigslist lately with a allison trans from school buses.
andrewmp6 is offline   Reply With Quote
Old 07-23-2012, 04:10 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Those are light truck engines as well... you need a commercial grade Diesel (like clinebarger posted) in that bus. Anything that comes out of a 1 ton or 3/4 ton light duty truck... ain't gonna cut it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-23-2012, 11:59 PM   #6
Captainfab
60-66 Nut
I couldn't agree more.
My vote goes with the Cat 3126
International DT466
Old 07-25-2012, 01:00 PM   #7
RebelChevy
the original diesel engines in this thing were either the cummins 5.9 or the cat 225. Granted these things were way under powered back in the 60's but i figured the 6.5 would be a significant upgrade. However, it wouldn't take much to convince me that even bigger is better! how complicated is the swap for these? I was going with the 6.5 for the bolt in mounting and the easy wiring.
Old 07-25-2012, 11:52 PM   #8
clinebarger
The Cummins 5.9L 6BT debuted in 1983.
Most older diesel powered buses/coaches had 2-stroke Detroit Diesels, Like the 6V-71 & 8V-71.
A 6.5L TD isnt a upgrade to ANY diesel....Except maybe a 5.7L diesel or a broke 6.5L, & will NOT be a direct swap!
The most "straight forward" diesel swap would be a Detroit 6V-71....There is most likely a identical but Detroit Diesel powered chassis out there...But a Black smoke blowing, Underpowered, Loud, Oil leaking dog is what you will get.
Old 07-26-2012, 10:43 AM   #9
Redcap
The Green Leaker. Most efficient way to take perfectly good diesel and turn it into nothing but smoke and noise.
478m v6, 6.5, diesel, engine swap, swap
