Help with motor size on my 62 V6 ?
I just picked up this 62 v6 yep v6 this thing is running great but have no clue what size motor it has . Any one have any idea where I can find out ? Thanks all. Soon this will be as low as I can go with out bags.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
Re: Help with motor size on my 62 V6 ?
This should help...http://www.6066gmcguy.org/EngineData.htm
Thank you I got to take a look at this when I get home hopefully it helps
It should...I found a lot of info there when I got my 62 GMC V6....good luck!
Registered Loser
I don't know about 62's but my 63 has a plate on the driver side kick panel with the motor info. The most common V6 in this era GMC's was the 305.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#6 | |
As stated, there should be a plate the driver's side kick panel with the information. If not, it's on the front of the block. The 6066 GMC site will tell you anything you want to know (about the GMC V6, tread lightly if you want to stray from the V6) |
Yep I found out its a 305. Thanks guys.
Tags |
engine code, gmc 1500, vin number |
