Old 08-08-2012, 07:14 PM   #1
chase1873
chase1873's Avatar
Front Spring Lengths. Drop or Stock Height... Dimensions?
I was told by the previous owner that the truck had 2'' drop springs up front. How can I verify that this is true.
1970 C10 2wd Short Box
The front springs measure about 12.5'' when removed.
Mike
1970 C10 swb step side... needs everything.
chase1873 is offline   Reply With Quote
Old 08-10-2012, 11:45 AM   #2
Constructor1
Re: Front Spring Lengths. Drop or Stock Height... Dimensions?
I have wondered this exact same thing for my truck. Is it possible to tell by the uncompressed length? When the spring weakens over time, will the uncompressed length change?
I am in the middle of frame off and will be doing a 2 1/2" drop spindle in front and possibly add a 1' drop spring, but want to see how it sits with the spindle first. My concern is that with the old spring, that it may already have a bit of sag and changing to a 1" drop spring will not change the stance.
Constructor1 is offline   Reply With Quote
Old 08-10-2012, 02:45 PM   #3
chase1873
chase1873's Avatar
Im having a similar issue, I already purchased 2.5'' spindles and want 2'' springs as well. I was told that these are in fact 2'' drop springs, but want to verify that it is true.
Mike
dimensions, drop, height, spring, stock
