Old 09-09-2012, 07:15 PM   #1
1957project
1957project's Avatar
U-Joint help
I have a 1957 chevy 3600 truck that I'm putting 56 1/2 ton axels in. Does anyone know part numbers for the stock U joints for these two trucks. No parts places have been able to find anything for me, they say they both use the same joint. The 3/4 ton caps are larger for sure.
1957project is offline   Reply With Quote
Old 09-09-2012, 08:15 PM   #2
parkwood
parkwood's Avatar
Re: U-Joint help
check out thetruckandcarshow.com look on page 108 they list 3 sizes for your year truck...
hope this helps you
parkwood is offline   Reply With Quote
Old 09-09-2012, 08:39 PM   #3
1957project
Re: U-Joint help
I couldn't find that website. Do you have a direct link for it?
Old 09-09-2012, 09:31 PM   #4
mr48chev
mr48chev's Avatar
Re: U-Joint help
Did you change drive shafts? If not you will have to use a conversion joint with two different size trunnions on it.
Old 09-09-2012, 10:21 PM   #5
1957project
Re: U-Joint help
I'm using the stock 2 piece driveshaft right now. I was hoping to find the two stock u-joints 3/4 and 1/2 ton, so I could get the specs from them and order a speciality u-joint. The truck is a stock 4speed manual.
Old 09-09-2012, 11:20 PM   #6
parkwood
parkwood's Avatar
Re: U-Joint help
www.truckandcarshop.com if that doesn't work eaither google or bing it and it should come up.. page 108
Old 09-10-2012, 12:58 PM   #7
mr48chev
mr48chev's Avatar
Re: U-Joint help
I'm seeing that the truck takes a Spicer 5-178X with 1.88 cup diameter while the rear axle takes a 5-153X with a 1.062 cup diameter
Check for a Spicer 5-460X as that should be the conversion cross that should work. The spicer numbers will translate to any other brand of U joints that have conversion joints.
The Neapco number is 11-131050
There is some good info here on id of u joints. http://www.driveshaftspecialist.com/...D%20Guide.html
Spicer has a pretty nifty page here that you can ID the u joint that should fit a certain application. That may help other guys with rear axle swaps. Just plug in the doner vehicle info and it gives the U joint numbers and placement. http://www2.dana.com/expertforms/dek350.aspx
Old 09-10-2012, 10:47 PM   #8
1957project
Re: U-Joint help
Thanks very much for all the info. This should save me a ton of time. Can't wait to get it back on the road this weekend.
