09-16-2012, 09:31 PM | #1 |
72 gmc cab on 73 4x4 frame
Anyone do this sort of swap? I have a 72 gmc 1 ton 2wd long box stepside and a 1973 shortbox stepside 4x4 with 1 Ton axles , 11" suspension lift and 44" boggers. Cab is shot on the 73 and frame shot on the 72
Posted via Mobile Device |
09-16-2012, 10:53 PM | #2 |
Re: 72 gmc cab on 73 4x4 frame
Also have a short box stepside from a 1972 Cheyenne 10 I plan on using with the cab. Full body restore is planned and no fuel tanks as its going on propane.
09-18-2012, 06:42 PM | #3 |
SWB 4x4 Collector
Look up member "MUDDER", either message him or do a search for his old posts and he should explain how to do it. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
09-18-2012, 08:43 PM | #4 |
sounds like it will be an interesting build to say the least
09-23-2012, 10:24 AM | #5 |
Should look good when it's done, rather lifted then lowered. Canada is unforgiving with slammed trucks and cars
09-27-2012, 01:37 AM | #6 |
i thought about doing this, then thought it would be easier to use the srping mounts from the 73 frame onto the 72 frame, but i got lucky and got a 70 4x4 frame. It can be done custom cab mounts, won't sit down low on the frame.
