Old 09-26-2012, 03:00 AM   #1
Briggz29
Briggz29's Avatar
gas pedal adjustment
hi I just finished an engine swap and i noticed that my gas pedal doesnt have enough movement to floor my new carb. is there an easy adjustment?
1985 Chevy C10 swb 350
Briggz29 is offline   Reply With Quote
Old 09-26-2012, 12:27 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: gas pedal adjustment
Zip ties?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-26-2012, 12:37 PM   #3
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Can you adjust the throttle cable by the bracket with the square hole on the engine? Either on the intake or bolted to the back of the carb.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 09-26-2012, 01:57 PM   #4
Briggz29
Briggz29's Avatar
The cable has enough room to open the throttle like the bracket is far enough back it's just the pedal that is to close to the floor there's not enough room to pull the cable tight
Old 09-26-2012, 02:20 PM   #5
83swb
Not sure what your running for a carb, linkage or cable but seems like you just need to take up some slack on the cable.
83swb is offline   Reply With Quote
Old 09-26-2012, 02:42 PM   #6
ont_guy_38
ont_guy_38's Avatar
What you basically have to do is leave the cable attached to the carb then unbolt the bracket and pull the bracket back till the slack is out of the cable then somehow attch the bracket there . I purchased an AED aluminum throttle bracket for mine and that solved all my problems . Was 80 bucks but money well as easy adjustment for any carb i install now .
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 09-27-2012, 11:55 PM   #7
78maliburat
To raise up the pedal take a butt wire connector and remove the plastic shell....... Open up the aluminum and slide it over the cable by the pedal ....slide it towards the pedal raising the pedal and crimp it
78maliburat is offline   Reply With Quote
carb issues, gas, gas pedal, pedal, throttle
