Old 09-29-2012, 06:39 PM   #1
blazerboy_4life
70Custom10
Lets see your Creative Plumbing and under hood accessory management...
I see a lot of people doing some pretty nice wire management. How about all mater of pipe/hoses/lines etc... including radiator hoses, heater hoses, brake lines, ac lines, fuel lines, hydro boost/power steering, air lines, vacuum lines or whatever plumbing you might have. Post up a pic with a little description. Maybe how you got to that point, why you modified your plumbing and how its worked out for you so far. Would you do anything different? I dont have any good pics to post up yet. When Im done with my truck (someday ) I plan to open my hood and see nothing but an engine. I want to make it look like there IS NO wiring or plumbing. I want people to look at it and scratch their heads wondering how the heck it even runs...
Ready...
Set...
GO!
blazerboy_4life is offline   Reply With Quote
Old 09-29-2012, 08:48 PM   #2
blazerboy_4life
70Custom10
Re: Lets see your Creative Plumbing and under hood accessory management...
No takers huh?
Old 09-29-2012, 10:09 PM   #3
bigguy69
dazed and confused
bigguy69's Avatar
Big al has a nice setup. If you do a search with his name I think his build will pop up
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 09-30-2012, 12:16 AM   #4
Andy4639
Old member
Andy4639's Avatar
Question Re: Lets see your Creative Plumbing and under hood accessory management...
Don't know if this is what your looking for but...I cut a length of aluminum conduit and made a top radiator hose.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-30-2012, 11:50 AM   #5
blazerboy_4life
70Custom10
Yeah this is the kind of stuff Im looking for. Why did you use the solid conduit?
Old 09-30-2012, 01:13 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Andy did you get your shifter wiring sorted out?
BBforlife there is a thread saying show me your engines that will give you a lot of ideas.
I'll link it if I can find it.
Here is one-------http://67-72chevytrucks.com/vboard/showthread.php?t=378111
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-30-2012, 02:02 PM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: Lets see your Creative Plumbing and under hood accessory management...
blazerboy_4life,
The conduit fit the regular rubber hose inside diameter perfectly. So all I did was cut enough off the old hose to secure it.
VetteVet,
Yes,
waiting on a micro switch for it. Well I think I have it figured out any way.
hoses, lines, pipes, plumbing, vacuum
