Old 10-18-2012, 12:49 AM   #1
NewType72
NewType72's Avatar
Radio head unit help
Hello I'm never usually in this are of the board but doesn't mean the family doesnt own just about ever year from 72-2001 but I'm hear to ask about the radio head unit in my mom's 96 Chevy pickup. I hear they go out pretty easy and since it's about 16 years old it seems to have given up the ghost so now here's my question
Where is the best place I can find a new/reman'd head unit to replace it and how difficult other than pulling the bezel off and disconnecting and swapping units?
Found this in a quick 5 min search
http://www.ebay.com/itm/Chevy-OEM-AM...61c688&vxp=mtr
Thanks for any info and advice in advance
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 10-18-2012, 01:06 AM   #2
dishow
dishow's Avatar
Re: Radio head unit help
That should be it. Plug and play.
90 Chevy 454 ss
Old 10-18-2012, 01:13 AM   #3
NewType72
NewType72's Avatar
as for buying a new unit though where would I go?
- Dylan
(209)-985-7721
Old 10-18-2012, 05:54 AM   #4
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
If you need a new factory unit you'll probably have to get it from a dealership.
Or you could get an aftermarket unit from many places, and install yourself or have it installed.
93 Yukon
89 Silverado Z71 SWB Sport
91 K 2500 Silverado "Lobuk-Worktruk"
A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO.
Gettin' old ain't for sissies.
TennesseeZ is offline   Reply With Quote
Old 10-18-2012, 08:02 AM   #5
1badgmc
1badgmc's Avatar
It's really not that much harder to install an aftermarket head unit than another factory one and you'd probably end up paying as much for a good factory unit.
When I bought my Suburban, none of the button illumination worked. Though it functioned perfectly, the lack of lighting drove me nuts. I resisted going aftermarket for a while because most of the aftermarket head units you see in these trucks use a crappy kit and stick out. I found a kit that mounts it nice and flush, so I went ahead and put in a nice Alpine I had laying around.
Old 10-18-2012, 04:36 PM   #6
NewType72
NewType72's Avatar
Alright well I'm sure you have the write up and info on the aftermarket panel you used right? ^^ I'll look into that and I just called the dealership they quoted me 1,016$ for a brand new radio head unit sonill definitely pass on that I may just buy this eBay unit
- Dylan
(209)-985-7721
Old 10-18-2012, 08:32 PM   #7
1badgmc
1badgmc's Avatar
The dash kit I used was made by Metra, part #99-3002. You can also buy a wiring harness that you splice into your aftermarket head unit's harness and then it just plugs into your stock harness so that you don't have to cut any stock wires. I paid $5 for mine. It was also made by Metra, part #GM-4001.
I don't have a write-up, but it is all very straightforward. The front dash bezel just pulls off. The HVAC controls have to be pulled out first before the radio. They use 7mm screws. Once you have it loose, pull the head unit out and unplug it. Plug your harness for the new head unit into the truck wiring and install the dash kit and head unit according to the included instructions and put it all back together. I spent maybe 20-30 minutes on my install.
Old 10-18-2012, 11:13 PM   #8
RayInAlaska
To me the best idea would be to get rid of the old unit and buy a new one. Also, when buying a new one, I would consider iPod or another MP3 player connectivity to it. If that's what you want, you should be able to buy a new one from Crutchfield (crutchfield.com) for around $120.00.
I am not trying to advertise for Crutchfield, but I do buy from this company every now and then. When you go to their website and find the automobile receivers and such, you enter your vehicle model and year, and a series of components will appear on the screen for you to choose from. Once you have chosen the one you want to buy, Crutchfield sends you a small harness with a plug or two (depending on which vehicle you have) installed on the harness.
The plug and the instructions are free, but you will have to solder the harness/plug to the harness on the new radio. Just follow the wire color codes. Once this is done, all you do is to connect the new harness/plugs to your vehicle radio's harness. When you buy from Crutchfield, shipment is free, and their technical advise on the telephone or e-mail is free as long as you own the radio.
RayInAlaska is offline   Reply With Quote
Old 10-18-2012, 11:27 PM   #9
1badgmc
1badgmc's Avatar
One of my favorite things about my Alpine is its USB port. I can load up one of my thumb drives with MP3s and have music for days.
Old 10-18-2012, 11:29 PM   #10
NewType72
NewType72's Avatar
well the truck is my moms she just got the new iphone im unsure how many new decks support her new usb cable but who knows something to look into that site is really cool i just have to research it a little more
- Dylan
(209)-985-7721
Old 10-19-2012, 01:00 AM   #11
RayInAlaska
New iPhone? Then look for a unit with both iPhone compatibility, and Bluetooth (Alpine, Kentwood, and the rest have both features).
Old 10-19-2012, 01:05 AM   #12
NewType72
NewType72's Avatar
right just curious if they have the new software the whole plug was changed anyway not super important for the hookup at this point. and 1BadGMC i was able to pull the head unit out without messing with the a/c panel to check the wires before. I'll keep researching thanks for the info guys
- Dylan
(209)-985-7721
Old 10-19-2012, 01:38 AM   #13
RayInAlaska
Talk to one of the Crutchfield advisors during the day. They may have adapters and things like that you can use with the new iPhone.
Old 10-19-2012, 08:02 AM   #14
1badgmc
1badgmc's Avatar
Ok...Maybe I was backwards and the radio has to come out for the HVAC to come out. It's been a couple years. I had to pull both units out anyhow since I put blue LEDs in my HVAC at the same time I did my head unit install.
audio, radio, replacement, swap, unit
