Old 10-19-2012, 10:43 PM   #1
DoubleL
DoubleL's Avatar
DoubleL's '66 Project
Well I should probably start a build thread I have certainly asked enough questions on these boards! In about April 2012 I decided to get rid of my ailing S-10 and get a small, economical truck. So.......I ended up with a 1966 C20 Custom Camper with a granny 4speed on the floor with 4:11 gears and a 292.
DoubleL is offline   Reply With Quote
Old 10-19-2012, 10:46 PM   #2
DoubleL
DoubleL's Avatar
Re: DoubleL's '66 Project
I had barely had the truck a week when I found a guy on CL with a new, never installed, Clifford manifold and Holley carb. He also had a set of long tube headers and an HEI for my truck. He only wanted $700 for the whole thing so I sweet talked my wife into taking the $700 and we drove almost 2 hours to get the stuff.
Old 10-19-2012, 10:50 PM   #3
DoubleL
DoubleL's Avatar
My first goal was to turn it into my daily driver. I ordered all new hoses, a belt, new spark plugs and new valve cover and side cover gaskets. Here are some before pictures. Like my fancy shop light?
Old 10-19-2012, 10:54 PM   #4
DoubleL
DoubleL's Avatar
It took me a couple days to get it cleaned up and all the new parts installed. I used a Remco gasket for the intake/exhaust. I cleaned the engine compartment and painted it up a little.
Old 10-19-2012, 10:56 PM   #5
DoubleL
DoubleL's Avatar
I decided pretty early on to put a 700r4 into it. I have a fairly short commute but it is all Highway and I needed another gear! Will add pics of that later.
Old 10-19-2012, 10:59 PM   #6
rcbildr
rcbildr's Avatar
Sweet!!!! Kind of ironic...a 66 3/4ton truck is "small and economical"
I think I pass by you on hwy 2 quite often. Usually, just west of monroe around 3pm ish. I'm heading westbound in a camaro with a rusty cowl induction hood....and I see a blue truck like yours heading eastbound.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 10-19-2012, 11:10 PM   #7
DoubleL
DoubleL's Avatar
I work in Lake Stevens and I'm headed home by 3:30! I'll keep an eye out for ya! I have a 3:73 posi I will be putting in it next week.
Old 10-19-2012, 11:21 PM   #8
rcbildr
rcbildr's Avatar
Cool!!! If all goes well tomorrow/this weekend you might see me in my 1960 GMC instead...just bought the parts I need to make it running and road worthy.
My Projects:
1978 Camaro Z28
Old 10-19-2012, 11:24 PM   #9
DoubleL
DoubleL's Avatar
I'll definitely notice that truck!
Old 10-25-2012, 09:34 PM   #10
DoubleL
DoubleL's Avatar
Inner and outer tie-rod ends installed today. Then an alignment. Tomorrow I am going to hit all the lube fittings and change the oil. I think my oil pan gasket is leaking....it figures, it is the only gasket i haven't replaced.
My 1965 C-20 project
https://67-72chevytrucks.com/vboard/...d.php?t=835095
Old 10-25-2012, 11:51 PM   #11
CRGRS 66
CRGRS 66's Avatar
Love the 6's, nice looking truck!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 10-26-2012, 10:14 PM   #12
jdl71
jdl71's Avatar
Looks great! Love the 6's too, just wish I had one
jdl71 is offline   Reply With Quote
Old 10-29-2012, 10:12 PM   #13
DoubleL
DoubleL's Avatar
Thanks man...you still looking for a clock for your cluster? PM me if you want
I really like the six too it's like me......a little different
Old 10-29-2012, 10:17 PM   #14
DoubleL
DoubleL's Avatar
I also picked up some motor mounts. That's my next project. This week I actually wrote out a list with everything I wanted to do. I prioritized it into several categories. Safety and mechanical were first, then I went on with my wants and wishes. The list helped me get my priorities and not get overwhelmed. I will post pics of the motor mounts when I get to that project. My biggest project will be swapping out the rearend and it looks like that will be Mid-November. I'll get some pics of that too.
Old 10-29-2012, 10:23 PM   #15
Ta2Don
Ta2Don's Avatar
IMHO The 66 is much cooler than an S10...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 11-02-2012, 04:01 PM   #16
DoubleL
DoubleL's Avatar
I agree!!
Old 11-02-2012, 04:08 PM   #17
DoubleL
DoubleL's Avatar
Just ordered a new wiring harness for underdash as well as front harness (alternator, regulator and such) engine harness(gauges, starter, HEI, etc) gauge cluster harness and fuel sender harness. I am having some charging problems and had a small fire at my fuel gauge a while back. I think there is some hidden damage in the main wiring harness. I was going to trace everything out but decided to just rewire the truck. The wires are all going on 50 years old anyway and this gives me the change to go to full gauges as well.
Old 11-04-2012, 06:28 PM   #18
pdxhall
pdxhall's Avatar
Welcome to the forum. It looks like you're really moving right along. I also made a list of what I'm going to do, and then check things off as I go. I try to stay on track but I leave myself the options to stop and work on another phase of the build if I need a change and being able to look back on what's been checked off the list helps keep things in perspective as to what I've accomplished.
pdxhall is offline   Reply With Quote
Old 11-04-2012, 07:47 PM   #19
Bomp
Bomp's Avatar
Welcome
I had a list kinda once.
Your off to a great start.
Subscribed.
Bomp is offline   Reply With Quote
Old 11-07-2012, 01:47 AM   #20
Terry12
DoubleL, what have done as far as the exhaust now that you installed your new headers?
Terry12 is offline   Reply With Quote
Old 11-07-2012, 08:33 PM   #21
DoubleL
DoubleL's Avatar
I'm actually running kind of a temp setup. I have both headers going into a 2 3/4 pipe with a glasspack. I am probably going to be putting the gas tank in the back and will eventually run dual pipes outside the framerails.
Old 11-07-2012, 11:03 PM   #22
DoubleL
DoubleL's Avatar
I want to accomplish two things on my 4 day weekend. Rewire the front and cab of the truck and come up with a plan for dealing with my interior leak and the rusty upper A-pillars on the cab. I have seen evidence of a lot of half-a## work by the PO.
Old 11-07-2012, 11:09 PM   #23
DoubleL
DoubleL's Avatar
Got my wire harnesses in the mail today! Rewiring is going to start in a couple days but first I wanted to get that carpet out and check out my cab. The back of the seat was pretty nice under the seat cover.....the bottom not so much.
Old 11-07-2012, 11:12 PM   #24
DoubleL
DoubleL's Avatar
The carpet had been laid down over the old rotten mat and a few shoddy repairs were made at some point. The rust in the cab is pretty bad. Disappointing but not really unexpected. This was rusted like this when I got it but wasn't visible from the outside. I think at some point the PO threw paint on it and put a carpet in to sell it. I hope I can fix this.
Old 11-07-2012, 11:17 PM   #25
DoubleL
DoubleL's Avatar
A few more pics of the cab.
