Old 10-31-2012, 06:07 AM   #1
shipma2
203 to 205 t case swap?
how do i swap a 203 out for a 205 on a th350 transmisson? input shaft and different front drive line?
shipma2 is offline   Reply With Quote
Old 10-31-2012, 06:15 AM   #2
jjzepplin
jjzepplin's Avatar
Re: 203 to 205 t case swap?
The output shaft should be OK but you will need the adapter and coupler, shifter and maybe some drive line work depending on the year unit you acquire.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-31-2012, 10:26 AM   #3
shipma2
alrighty then thanks
transfer case
