Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Closed Thread
Old 11-04-2012, 11:09 AM   #1
GEARBOXGARAGE
HD Chromoly Panhard Bars
The Gearbox Garage announces the introduction of their G-TR Precicion Components Heavy Duty Double-adjust Chromoly Panhard Bars for '65-72 GM Trucks with coil spring rear suspension with 0"-4" of drop. Introductory retail price is $119.99, forum members save 10%, making the price $107.99. Each kit comes complete with QA1 XM Series Rod Ends and all necessary Grade 8 Hardware to install and are Black Powdercoated.
GEARBOXGARAGE is offline
Old 11-06-2012, 10:30 AM   #2
Custom 68
Custom 68's Avatar
Re: HD Chromoly Panhard Bars
a couple questions:
does this mount in the factory location? and is factory length (only adjustable) or is this a long bar with the additional brackets to mount from side to side? Any install pics?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline
Old 11-06-2012, 01:15 PM   #3
GEARBOXGARAGE
Dave,
Yes, this mounts in the factory location for "mild" drop applications of 4" or less. They adjust at both ends through RH and LH threaded Chromoly Rod Ends, so there is no need to remove one end to adjust the position of the rear-end. Just install each end, adjust to desired length, and tighten the jam nuts. I will post up some install pics this evening or early tomorrow.
Thanks,
Mike
Old 11-06-2012, 07:18 PM   #4
SCOTI
SCOTI's Avatar
A short 'easily' adjustable PHB has been sorely missed in the market. Kudos for stepping up & filling the need.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 11-06-2012, 08:21 PM   #5
chapster
chapster's Avatar
X2
Also really nice to see the hardware as a kit because it is very frustrating dealing with missing hardware and having to wait weeks/months for replacements.
Nice job!
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline
Old 11-07-2012, 09:45 AM   #6
GEARBOXGARAGE
Thanks, guys! Yeah, we are trying to make our kits as complete as possible, this does increase the cost a little, but much better in the end for the customer.
P.S. We will be posting some install pics later today!
Old 11-07-2012, 10:08 AM   #7
Custom 68
Custom 68's Avatar
Yes this is great news, thanks for the info.
Dave
Old 11-07-2012, 09:10 PM   #8
GEARBOXGARAGE
Install pics on a '66 with 4" drop springs.....
Old 12-06-2012, 03:44 PM   #9
GEARBOXGARAGE
Still have some of our HD Panhard Bars under the introductory pricing. Forum member price $107.99!
Old 01-03-2013, 01:33 AM   #10
mikey2409
Are those panhard bars single or dual sided on the adjuster
mikey2409 is offline
Old 01-03-2013, 09:38 AM   #11
GEARBOXGARAGE
They are adjustable at both ends, with right and left hand threaded rod ends so the length can be adjusted without removing from the truck.
Old 04-02-2013, 09:30 PM   #12
GEARBOXGARAGE
Our Extended "Series 2" Panhard Bars are ready to release! They will offer the same quality TIG welded 1-1/4" Chrome-moly tubes and XM Series Rod Ends at both ends to simplify adjustability. All necessary Grade 8 hardware is included, as well as new U-bolts. The trailing arm mount provides 3 holes to adjust roll center, and also moving the mounting point back for a high clearance design when running large diff covers while maintaining a straight bar. Bars and mounting brackets come in Satin Black Powder Coat finish. Retail price is set at $189.99, with forum member discounts set at $15 off!
Old 12-07-2013, 10:51 AM   #13
GEARBOXGARAGE
Christmas Special Get free shipping along with Forum member pricing of $107.99 on our Series 1 Chrome-moly Panhard Bars. They're fully TIG Welded with an integrated wrench hex on one end for easy tightening of the jam nuts and come Satin Black powder coated. XM Series Chrome-moly heim joints at both ends making adjustments quick and easy without having to unbolt them from the chassis. All Grade 8 mounting hardware is included. These are for stock to mild drops of 4" or less.
Old 12-07-2013, 12:24 PM   #14
SCOTI
SCOTI's Avatar
What is the range of length for the shorter bar (for the 6x-72 app)?
Do or can you make 'custom lengths'?
What size are the retaining bolts?
I have a custom app. I noticed this & remembered the OE 6x-72 bars are pretty close to what I need.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 12-08-2013, 06:39 AM   #15
chevy-fun
chevy-fun's Avatar
anything for 73-87 trucks. like to have one for my 10 bolt. prefer a bolt on kit. something similar to ridetech bolt on one in their 4 link kit. but they don't sell it separately.
chevy-fun is offline
Old 12-09-2013, 09:37 AM   #16
GEARBOXGARAGE
SCOTI - The range is approximately 23-1/4" to 24-1/2" with 5/8" bolts to attach the heim joints to the frame. Currently, we are not producing custom lengths.
chevy-fun - Sorry, we don't have anything similar to that bracket at this time.
Old 12-16-2013, 03:46 PM   #17
Number98
Prestige Worldwide
Number98's Avatar
Do you know if your extended bar will clear the PML Style covers that are deeper for more fluid?
Here is a link to the cover I am referring to: http://www.yourcovers.com/diffcover_6058.php
Thanks,
Jason
Number98 is offline
Old 12-16-2013, 06:30 PM   #18
GEARBOXGARAGE
Thanks,
Jason
Jason,
I can't say for sure as I haven't used these specific covers. We created a mounting point on the trailing arm bracket that would clear T/A style covers, but I'm not sure how much of a dimensional difference there is between the two styles. I'm attaching another shot of our extended bar used in our coil-over set-up, which utilizes the same mounting point on the trailing arm. This angle may help visualize the clearance you are questioning. Sorry I cannot give you a definite answer on this one.
Thanks,
Old 12-22-2013, 11:58 AM   #19
Number98
Prestige Worldwide
Number98's Avatar
Thanks for the picture....
I actually have a T/A style cover and one of the PM L's, I will dig them both out and measure them out and let you know.
Jason
Number98 is offline
Old 12-23-2013, 01:19 AM   #20
GEARBOXGARAGE
Jason
Jason,
Sounds great, I'm definitely interested in seeing how they compare.
Old 03-18-2016, 11:15 AM   #21
SIXTY9
Are you still selling the panhard bars? That is one very good looking truck yall built.
SIXTY9 is offline
Old 03-18-2016, 11:56 AM   #22
GEARBOXGARAGE
Thanks for the compliment on our shop truck!
Yes we still have them, are you looking at the Series 1 (for 4" drop or less) or the Series 2 (for 5" drop or more)?
Old 03-18-2016, 12:46 PM   #23
SIXTY9
Series 1, I only took it down 1 1/2 inches. Going to pick it up from paint in Georgia in a few weeks. I will be in touch to order it soon. Thanks
SIXTY9 is offline
Old 03-19-2016, 10:44 AM   #24
GEARBOXGARAGE
Sounds good.
Thanks!
Closed Thread
