06-02-2003, 05:53 PM | #1 |
4.3 experts please
I just got a 4.3/700R4 from an Astro van. It is computer controlled but does have a carb. I'm putting it into an International Scout. Is there a way I can delete the computer? Thanks
'69 SWB '76 International "Terra" "Hooked on holiday beer" |
06-02-2003, 06:33 PM | #2 |
STILL PLAYS WITH TRUX
Yes,
If the eng.'s got a carb then it wasn't that dependent on the computer to run just install a regular carb. and ues a non computer HEI distributor. For the trany you will need to get a TCC by pass kit and that will allow you to operate it without a computer and still have the overdrive gear. I think that should do it. Good luck. |
06-02-2003, 11:01 PM | #3 |
Great. The dis on it right now looks and hooks up just like the early V-8 type HEI's (one wire for 12 volts and one for the tach). This dis should work right?
06-03-2003, 06:46 PM | #4 |
Yep,
If there's no wires going to the computer your good to go! Im shure your aware that you will have to use differant sending unit's for all your engine vitills! |
06-03-2003, 09:07 PM | #5 | |
driving is in my blood
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
