Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 11-16-2012, 09:36 PM   #1
69SCSS
69SCSS's Avatar
Tools for cutting bolts
hey guys, just wondering what you guys use for cutting off bolts when they are rusted solid. I used my 4.5" Angle grinder with a cutting wheel to get my U bolts off the rear that were stuck, and went thru 2 blades. I was leery of using the sawzall with the metal blade just because I was worried about hitting the axle tube.
I have a decent Craftsman 4.5 angle grinder and used some standard ACE blades, not sure what brand. They worked but got eaten up pretty quick, but did the job. next up is the cab to frame bolts!
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 11-16-2012, 09:42 PM   #2
Tinkermc
Re: Tools for cutting bolts
I use a 3.5 cut off air operated cut off wheel
Tinkermc is offline   Reply With Quote
Old 11-17-2012, 12:14 AM   #3
71K20chevy
71K20chevy's Avatar
^^This is what I find the easiest too.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 11-17-2012, 12:24 AM   #4
LEEVON
LEEVON's Avatar
Get some better cut off wheels for your angle grinder. The dewalt ones last longer, I could make short work of some u-bolts for sure.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-17-2012, 02:31 AM   #5
Gumby
Gumby's Avatar
get an air chisel, with the V grove bit and keep it sharp, makes quick work of stuborn things, even better if you drill a hole through or part way into it, smaller bites shear quicker.
Gumby is offline   Reply With Quote
Old 11-17-2012, 02:38 AM   #6
69SCSS
69SCSS's Avatar
Well I don't have an air compressor, but I will try some different cutting wheels. I haven't tried to move the cab bolts yet, that's for monday's fun. I'll try and unbolt them first, but if that doesn't work... I'll be cutting!
Thanks guys.
My 68 SWB
Al Silveira Music
Old 11-17-2012, 03:33 AM   #7
bk2life
cuttin wheels are top notch. dont be afraid of that sawzall either! my best friend for cuttin things, my plasma cutter! cant do with out that tool!
bk2life is offline   Reply With Quote
Old 11-17-2012, 04:49 AM   #8
Gumby
Gumby's Avatar
if your having trouble breaking the thin ones, grab a metal griding wheel, they will cut through, just a wider cut.
Old 11-17-2012, 01:36 PM   #9
cdowns
cdowns's Avatar
for smaller bolts 3/8 and under i find it is easiest to just tighten and snap them
Old 11-18-2012, 04:17 AM   #10
ssapach
ssapach's Avatar
Depends on location, but oxy/acetylene torch is my favourite so far. With a smaller torch it can reach into places grinders can't.
ssapach is offline   Reply With Quote
Old 11-19-2012, 03:41 PM   #11
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Times (2) on this tip. I have used a flex-head breaker bar in the past to carry out this task
johnnyclack is offline   Reply With Quote
Old 11-22-2012, 12:06 PM   #12
67ChevNut
Active Member
Smile Re: Tools for cutting bolts
Great tips guys, I know I'll be using all of them.
67ChevNut is offline   Reply With Quote
Old 11-22-2012, 12:58 PM   #13
johnnyclack
No air?, I understand /been there
There is always the ol’ stand-by, don’t underrate a sharp chisel & a good ball peen hammer.
Back in the old days before all the new innovative tools hit the shelves allot of things were built and or modified using a good hammer and a sharp punch & chisel set
