Old 06-03-2003, 04:57 PM   #1
gldevall
gldevall's Avatar
Help with tire sizes
I am in need of new tires. New engine. go figure. LOL. Anyway currently I am running 15x8 wheels with 255/60 out back and 235/60 up front. I would like to with a wider rear. Any suggestions? No, I'm not buying new wheels, right now.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 06-03-2003, 05:20 PM   #2
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
I like my 275's but if I was rich like 82BlackBeast I would be running 315's
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 06-03-2003, 05:35 PM   #3
PHOENIX
You can safely fit up to a 295 on an 8" wide wheel (maybe even wider).
Some do not recommend it, but I run them on the front and back with no problems (My front 15x8, my back 15x10). So anything between your current and 295's should not be a problem.
Example:
295/50/R15
295 Represents Tire Width
50 Represents the Tire Aspect Ration (Side Wall)
The tire aspect ratio changes with tire width.
So a 255/50/R15 and a 295/50/R15 will not have the same side wall height!
R15 Represents wheel diameter in inches.
Here is a web site that should be helpful in determining the tire size you want:
http://www.miata.net/garage/tirecalc.html
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 06-03-2003, 11:44 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Cheap tires on ebay.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-04-2003, 02:22 AM   #5
slammedLT1
slammedLT1's Avatar
i just got my rims and tires mounted
last year i had 15x8s with 235/60 and it was perfectly fine never rubbed up front, i have 245/60s now and the are rubbing on sharp turning ... as for out back i had 275/60s on 15x10s and they rubbed the sidewall when i took a big bump as for now i have 15x8s with 295s and they are perfectly clear of the wheel wells,. that was with my 5/6 drop aswell
if i was going to buy new tires (just picked up mine used 10% wear on them) id go with 235/60 and 295/50s
DIGGER
1984 GMC Sierra 1500 LQ4 T56 12B Chopped 2 1/4, Dropped 6/7, Shaved, Yenko Stripes
2004.5 CCSB GMC 2500HD DMAX LLY, 6" Liftmaster, 6 Fox Resi 2.0 325/50/22" Kumho A/T on KMW's LBZ MP, 5"Ex, Bullydog GT
1996 ECSB GMC Sierra 1500 350/4L60E, FL Headers, 2450 Stall, 6" Pro Comp,3" BL, Shock Hoops, , TrXus STS 38's
slammedLT1 is offline   Reply With Quote
Old 06-04-2003, 02:28 AM   #6
ocbaud
Garage Queen Material
i am in need of new tires also.
i'm thinking either 255/60/15's all around or 245/60/15's in front and 295/50/15's in the back
ocbaud is offline   Reply With Quote
