Old 11-23-2012, 10:33 PM   #1
Bow Tie Scottie
Bow Tie Scottie's Avatar
Mechanical Fuel Pump - what to get
I think I have a suspecting failing fuel pump and I would like to replace it. Had it replaced 4 years ago with one from NAPA. After reading several posts on fuel issues, most of the symptoms lead to a faulty pump. So I have been shopping around and leaning towards an Edelbrock 1721 Performer fuel pump for around $100. I have seen pumps ranging in price from $20 to over $200 that could meet my specifications. What have you experienced with or recommend?
Sit back. Relax. Enjoy the ride!
86 Chevy Scottsdale C20, SBC 350, TH400, 4.10 gear ratio
Bow Tie Scottie is offline   Reply With Quote
Old 11-23-2012, 10:50 PM   #2
88Jimmy4x4
88Jimmy4x4's Avatar
Re: Mechanical Fuel Pump - what to get
ACDelco
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 11-23-2012, 11:34 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
2 line or 3 Carter
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-24-2012, 09:13 PM   #4
suxtobu65
suxtobu65's Avatar
I would highly recommend a 3-line.. Having a return line is recommended to help prevent vapor lock.. I'm currently dealing with this issue..
suxtobu65 is offline   Reply With Quote
Old 11-24-2012, 09:53 PM   #5
thesickc10
If you have a stock to mild motor a stock pump will do fine.
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 11-24-2012, 11:29 PM   #6
Bow Tie Scottie
Question: Does a mechanical fuel pump have gravity issues? My truck will fail trying to climb a steep hill, even if it is for a short distance. Will any fuel additive have an effect on a failing fuel pump?
Old 11-25-2012, 12:59 AM   #7
mongoose
mongoose's Avatar
kinda.. a bad pump will let fuel drain when it's sitting... hills = loads.. so carbed based.. fuel filter
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 11-25-2012, 01:36 PM   #8
jojoman
im currently dealing with a problem from this i put a 2 line performance pump and now truck like spits gas from the carb. like if it floods quick could it be from the pump. or do i just got to re adjust the carb. to it.
jojoman is offline   Reply With Quote
edelbrock, fuel pump
