Old 06-04-2003, 08:42 AM   #1
sider68
sider68's Avatar
Stereo Installation Help
What is the best for cutting the dash to install C D player?I didn,t want to go this route but my son shows up with his buddy and wired the system together but did not want to cut up dash and left me with the task
sider68 is offline   Reply With Quote
Old 06-04-2003, 09:30 AM   #2
Gibble
mmmm....Rye and Coke
Gibble's Avatar
Probably a jig saw with a proper blade, or a good cutting disc, barring that you can use a drill, then file/grind the hole smooth
Gibble is offline   Reply With Quote
Old 06-04-2003, 09:34 AM   #3
PHOENIX
If you have either of these air tools, you could use them for a fast, easy, and very clean cut:
If you do not have access to these tools, then I would recommend using something like this:
You may also want to use a drill to get some starter holes on the vertical cuts. Or you could cut both top and bottom, then bend the side inward (not as clean, but works and not visible after installation).
Whatever cutting tool you choose to use make sure the blade is for cutting thin steel. Using the wrong blade could make it harder to cut and the cut would not be as clean, possibly nasty.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 06-04-2003, 09:39 AM   #4
cochino12
It followed me home?
cochino12's Avatar
I would recommend the airsaw, it's a much cleaner cut
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 06-04-2003, 10:36 AM   #5
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
A dremel tool with a cut off wheel works great. Small and fast to use.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 06-04-2003, 02:06 PM   #6
sider68
sider68's Avatar
Thanks again,great tips.
Old 06-04-2003, 04:12 PM   #7
swervin ervin
You get what you pay for
swervin ervin's Avatar
A Rotozip with a metal cutting bit in it is a great tool for this.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 06-04-2003, 05:50 PM   #8
Russell
Professional Grade
Russell's Avatar
We wanted to install a temperature gauge in the 80 suburban as the stock one was removed and replaced with a tachometer years before. (it was an ambulance, only had 2 000 kilometers on it, was stored indoors and was maintained very well. It ran perfectly and was in complete mint condition, at least until we sold it to my uncle, my truck is in better shape now, a terrible waste of a truck...) Since we still wanted the tachometer, we just used a soldering iron to melt through the plastic dash and install the new temperature gauge, it looked totally factory installed and very clean. We needed the temperature gauge as we used it as a hauling vehicle, and it overheated on us once...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
