Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 12-13-2012, 07:32 PM   #1
andrewj1398
1964 c60 help
Hey everyone I am new to the forum! So thanks for the help in advance. I bought a 64 C60 from a buddy of mine last week. Once I got it home I realized there is a lot more rust in the floor pan than I originally thought. My question is I was on Top Banana's website and saw replacement floor pans with backing plates(item#: 01-0848-218) they look similar to my floor pans will they fit a C60? I have heard that the cab is the same as the C10 is this true?. So all of you C60 experts if you could help me out with some thoughts on some aftermarket rust patches for this beast that would be great!
andrewj1398 is offline   Reply With Quote
Old 12-13-2012, 08:10 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 1964 c60 help
I believe the firewall is a little deeper iirc, the floors I believe are exact or very close.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-13-2012, 10:49 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 1964 c60 help
the only issue you will have is if you have a lcf (short hood), otherwise about the only major difference with a c/60 c/10 cab is the flat floor hump (in the c/60), all the rust repair panels available will work on your truck.
the only piece that you might have a problem finding if it is also rusty is the center floor hump, which is flat and c/50-c/80 only.
some c/80's with the big allison 5 speed transmission came with a low floor hump, like you would find in a c/10 with a powerglide, or a 3 speed., this might be a consideration if you want an original floor mat, since they do not make the flat c/50-c/80 mat.
Old 12-14-2012, 01:38 AM   #4
travz500
travz500's Avatar
Re: 1964 c60 help
andrew if you need the center flat piece over the tranny I may be able to help you out wont be right away but i may be able to let me know if you think you might need this part pm me if u do
travz500 is offline   Reply With Quote
Old 12-14-2012, 01:59 AM   #5
MikeS.
MikeS.'s Avatar
Re: 1964 c60 help
Andrew
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 12-14-2012, 09:58 AM   #6
andrewj1398
Re: 1964 c60 help
It is a LCF. I will try and post pictures in a little bit. The rust is mainly near the doors not so much towards the center of the cab.
Old 12-14-2012, 11:12 AM   #7
andrewj1398
Re: 1964 c60 help
Here on some pictures of the driver and passenger floor boards. All the rust is at the door openings. I know I will have to replace both rockers and some of the floor boards. I want to save as much original metal as I can.
By the may this is a LCF!
Thanks for the help!
Old 12-14-2012, 11:18 AM   #8
andrewj1398
Re: 1964 c60 help
This is the truck previous owner named it "TOWMATER."
Where can I get a set of mirrors like that at?
Old 12-14-2012, 12:57 PM   #9
jonzcustomshop
1961 crewcab
Re: 1964 c60 help
so the good news is that the rust did not get into the lcf only part of the footwell.
you have a little fabrication ahead of you, but I still think you will benefit from front and side floor pans and outer rockers, the main difference in the lcf cab is where the footwell is modified for the tire clearance.
you do not need to buy inner rockers, because they are part of the front and side floor pans when you buy them.
also, good plan leaving as much original metal as you can, I suggest trim out what is bad, and use the patchpanels to fix, you might run into a small bit of fabrication if the rust got into the foot well , but it is not going to be any more work than your initial repair.
* super important on this kind of repair, as you cut out pieces of the rusty metal , save it all till you are done, you might need parts for patterns, and if the very front of the rocker panel is different than a c/10, you might need to cut and splice some of your old pieces.
btw, cool truck, what engine does it have?
Old 12-14-2012, 02:19 PM   #10
andrewj1398
Re: 1964 c60 help
Thanks! It has a 292 straight 6 cyl. Paid 1000 for it from a friend he had it sitting around not doing anything with it.
Old 12-14-2012, 02:49 PM   #11
andrewj1398
Re: 1964 c60 help
Just to make sure I need these parts on both sides right? Who sales the cheapest patch panels? These are from Top Banana.
Old 12-14-2012, 06:42 PM   #12
jonzcustomshop
1961 crewcab
Re: 1964 c60 help
since your rust does not continue all the way to the pedals, you might be able to get away with not purchasing those bigger flat pans in the last pic, looks like the piece in the first shot is big enough to cover the hole...
I don't know if you can find mirrors like that anymore....
Old 12-14-2012, 09:13 PM   #13
andrewj1398
Re: 1964 c60 help
Thanks. Maybe I will try and save these.
Old 12-15-2012, 12:41 AM   #14
Captainfab
60-66 Nut
Re: 1964 c60 help
What is wrong with the mirrors on it? The mirror glass itself can be replaced at a glass shop.
Some of your better auto parts suppliers can order replacement mirrors similar to those. They likely won't be able to find anything if you ask for mirrors for a '64 C60. You'll have to get a little creative and ask for a newer model truck. I have an '89 GMC 7500 that has similar mirrors.
Old 12-15-2012, 11:32 AM   #15
andrewj1398
Re: 1964 c60 help
Nothing is wrong with the mirrors them self. The bars are pretty rusted. I might take them apart and sand blast them and see what they are looking like.
Old 12-19-2012, 11:23 PM   #16
luvmytruck
Re: 1964 c60 help
I just finished installing rockers in my 65 c10 they were not as rusty as yours but I like new metal. here are some pics. I slowly cut away on the first one till I got a good fit. the second one went a lot faster.
luvmytruck is offline   Reply With Quote
Old 12-19-2012, 11:24 PM   #17
luvmytruck
Re: 1964 c60 help
more
Old 12-19-2012, 11:26 PM   #18
luvmytruck
Re: 1964 c60 help
and more
Old 12-19-2012, 11:27 PM   #19
luvmytruck
Re: 1964 c60 help
stitch weld into place then use a quality seam sealer inside and out
Old 12-19-2012, 11:29 PM   #20
luvmytruck
Re: 1964 c60 help
in order to get the panels into the tight corners, heat with torch and use a body hammer to tap into the tight spots
Old 12-19-2012, 11:31 PM   #21
luvmytruck
Re: 1964 c60 help
some more pics
Old 12-19-2012, 11:35 PM   #22
luvmytruck
Re: 1964 c60 help
the first one took a total of three or four hours but the second one only took about two hours
Old 12-19-2012, 11:38 PM   #23
luvmytruck
Re: 1964 c60 help
here are more pics not necessarily in order
Old 12-19-2012, 11:46 PM   #24
luvmytruck
Re: 1964 c60 help
close ups I also smoothed out the kick panel area while I was working in there
Old 12-21-2012, 02:19 AM   #25
dracko
dracko's Avatar
Re: 1964 c60 help
Very nice work. Make it look easy.
dracko is offline   Reply With Quote
