1984 Chevy C10 Gauges
Hello all,
I have a 1984 Chevy C10. The speedometer and gas gauges tend to jump around every time I hit a bump in the road. Is this normal for these older trucks? Can I do something for the gauges to stop bouncing around? Any insight will be great, thanks! Posted via Mobile Device |
Re: 1984 Chevy C10 Gauges
Mine shows different levels depending on if I'm accelerating or slowing down.
my speedo used to bounce around but hasnt since i put new cable on
the gas gauge i would check wires, probly one getin pinched between floor an frame or something like that |
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373 1984 Chevy C10 short bed 2001 Chevy Impala police cruiser 2001 Chevy Silverado 1500 Z71 4wd extended cab ![]() |
78K & 79C Jimmys
I had read about the bouncy gas gauge
heard it was because of aftermarket "Spectra" parts I could read that name on my tank assumed this was why my 78 gas gauge bounced with idiots I added a ground behind the cluster where they go too one,didn't help i bought and changed to a tach/gauge setup had to rewire it and had to add a seperate ground for the gauge and the bounce went away.... this past summer my 79 tank/sender rusted out replaced it with "spectra" parts as my auto parts guy said he's never heard of this prob no bounce speedo make sure it's in tight
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
That will be the first thing I'll check. Hopefully that's the problem, thanks guys!
Tags |
c10, gauges |
