Old 02-23-2013, 03:42 AM   #1
miketennis1
miketennis1's Avatar
Where do the heater hoses go??? I'm freezing!!!
Ok so I bought my 85 c10 3 years ago and I just now started working on it. I'm trying to make it my daily driver. The main problem I'm having is where do my heater hoses go? One is missing and the other is just really long and not connected to anything. I can't even tell where they go? If some one has a picture or a diagram or anything that could help me toget my heater working
miketennis1 is offline   Reply With Quote
Old 02-23-2013, 06:52 AM   #2
rs74
rs74's Avatar
Re: Where do the heater hoses go??? I'm freezing!!!
One should go to the intake and the other possibly your longer hose should go to the radiator.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-23-2013, 08:50 AM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
http://67-72chevytrucks.com/vboard/s...ht=heater+hose
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 02-24-2013, 09:54 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
if you need heat(sounds like it)
go pump to intake for better heat,takes longer off the rad
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-24-2013, 12:43 PM   #5
l1l
make sure you have a proper working rad , otherwise you'll be ending having all the water inside the cab.
l1l is offline   Reply With Quote
c10 2wd fleetside, heater, hoses
