Old 03-06-2013, 09:09 PM   #1
otiger50
otiger50's Avatar
1964 Chevrolet C10 2WD SWB
-Problem: Shifter through the floor moves freely side to side, thus, allowing it to fall out of gear.
-Source of problem: Shift linkage brackets are not secured due to previous owner's modifications (v8 sbc swap.)
Solution: Fabricate a bracket to hold the shifter in place!
I made the bracket to bolt into the two holes on the shift linkage bracket and to anchor onto the crossmember.
-Here is what I threw together:
Here is the general shape of the bracket after I had it welded together and before I drilled the holes. I just purchased a MIG welder a few weeks ago and I am using up the flux core wire that came with it, so the welds AREN'T VERY PRETTY! But hey, as long as they hold, it's alright. Right? Take a look:
Here is the bracked all welded and bolted into place:
otiger50 is offline   Reply With Quote
Old 03-06-2013, 09:14 PM   #2
otiger50
otiger50's Avatar
Re: 1964 Chevrolet C10 2WD SWB
The transmission doesn't fall out of gear anymore, but boy, does it make a lot of gear noise!
Now, I'm a beginner, but shouldn't the crossmember be supporting the transmission?
Kinda looks like the pinion angle is a little too high...
Old 03-06-2013, 09:18 PM   #3
otiger50
otiger50's Avatar
The wheels and bumper are a little rusty.
-Should I take a good ole wire brush and a can of primer and rust-oleum to them, or take them to get sandblasted and powder coated?
It really isn't a bad looking pickup!
Old 03-07-2013, 08:37 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
That is a really nice 64. If it were me, I would have the wheels sandblasted and powder coated if you are going to keep them for at least two years. It is more money but they will last longer.
TBONE1964 is offline   Reply With Quote
Old 03-16-2013, 01:51 PM   #5
otiger50
otiger50's Avatar
Took a little spray paint to the wheels and rear bumper to dress it up a little and an oil, trans, and differential fluid change never hurt!
great way to mask off a tire. loved it
acetone gets overspray off of tires pretty well for those "oops" moments
easily ground off all of the paint from the rear bumper with a wire brush on a right angle grinder. couple coats of primer and a couple coats of gloss. it's not the prettiest bumper but i'm on a bit of a budget on this one.
turned out not too bad!
Old 03-16-2013, 01:56 PM   #6
otiger50
otiger50's Avatar
interior could use a LITTLE help!
the LS donor Avalanche for my Nova project came with these freakin awesome leather seats let's start with some new seats and carpet!
Old 03-16-2013, 10:05 PM   #7
Rac65
I have not painted any wheels in a long time but the last time I did I rubbed dishwashing liquid on the tire let it dry, paint the wheel and when the paint dries just rinse the soap off.
Rac65 is offline   Reply With Quote
Old 03-16-2013, 11:04 PM   #8
otiger50
otiger50's Avatar
yea i just heard about the playing cards idea and had to try it!
Old 03-19-2013, 01:01 PM   #9
1963c-10
1963c-10's Avatar
If it had a muncie 3 speed originally, it would have been installed with the bellhousing that had the frame mounts. So they wouldn't have used a transmission crossmember. The autos did use them as well as alot of other standard transmissions.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
1964 short bed, interior, painting wheels
