Old 03-08-2013, 10:16 PM   #1
devinder8788
devinder8788's Avatar
coolant inside truck on floorboards
i was cleaning my truck out today and noticed how my carpets are wet i pushed my hand into the carpet and it was all green from the coolant and i had just filled my coolant last week does that mean its my heater core and if it is how do i change it "1986 sierra 1500 6.2 diesel
devinder8788 is offline   Reply With Quote
Old 03-08-2013, 10:31 PM   #2
Damon23
Damon23's Avatar
Re: coolant inside truck on floorboards
Heater core is leaking. I took one look at all that needed to be done and paid someone to do it.
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
Old 03-09-2013, 12:16 AM   #3
79Betty
79Betty's Avatar
Well if it has ac it's a pain! No ac then it's a lot more simple. Drop heater box under the dash and it's held in by 4 1/4" screws. The assenger side inner fender had to come out in my 79 and the outside box come off. Overall time maybe 2 hours... If that. But my truck is non ac.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 03-09-2013, 12:36 AM   #4
devinder8788
yeah i have no AC. so the mechanic doesn't have to take off my dashboard?
thinking if they have to then i might change my dash since its all cracked
Old 03-09-2013, 12:40 AM   #5
79Betty
79Betty's Avatar
Nah ya din't but u definetly need to take out the glove box. That makes it 200% easier.
Old 03-09-2013, 12:58 AM   #6
meatwagon83
meatwagon83's Avatar
heater core, pain in the ass
meatwagon83 is offline   Reply With Quote
Old 03-09-2013, 05:48 PM   #7
zaccaglin
zaccaglin's Avatar
If you have AC take it to a shop. Took the shop 6 hours to do mine because of the plastic cover over the AC stuff under the hood. Then they had problems dropping it inside because of the vaccume lines. They only charged me for the quoted two hours tho.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 03-09-2013, 08:08 PM   #8
rusty76
rusty76's Avatar
Now a years back and I mean years back, my uncle and myself changed the heater core in my truck. Yes it was a pain, but we didn't pull the cover off the firewall. Seems odd to me now but I don't rember it being six hours of work either. Yes my truck has AC and yeah it was a pain but I just don't remember pull the AC cover to get to it. I do know we dropped the glove box and worked under the dash. Maybe my memory is gone now....Still if I had the money I'd pay someone to do it and flush the cooling system too.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-10-2013, 05:04 PM   #9
Tucson38
Changed mine a couple years ago, wasn't as bad as I had anticipated (yes, I have A/C). Worst part was one bolt holding the cover on being hard to reach but just worked on it a while and got it out. Took about 6 hours working by myself, first attempt. Took the opportunity to clean everything up while I had it out. I'd do it again before hiring it out but I have more time than money. (85 GMC).
Plenty of experienced guys on this site, try a search and you'll find lots of helpful information.
Tucson38 is offline   Reply With Quote
Old 03-10-2013, 09:48 PM   #10
silvereagle07
silvereagle07's Avatar
No AC is easy. But I would drain the coolant from the block and radiator. Then flush it with water and vinegar. Flush with distilled water. Then fill with coolant and distilled water. Try to find a copper core if you can.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-11-2013, 08:50 AM   #11
Tucson38
Good advice on the copper core, I found one at O'Reilly's.
Old 03-11-2013, 04:42 PM   #12
Low87
been here longer than Liz
Low87's Avatar
It's a royal PITA. Did mine last year (I have AC).
Worst bolt is the one between the firewall and the inner fender. Had to use a long flexible ratchet extension to get it. Takes a couple hours to undo the 5-6 bolts to remove the interior cover. The swap itself is pretty easy.
Definitely one of those things that gets easier/quicker the more often you do it.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 03-14-2013, 09:48 AM   #13
billnorman
Watch out many replacements are Chinese and smaller than the origional.
billnorman is offline   Reply With Quote
Old 03-14-2013, 12:34 PM   #14
Ziegelsteinfaust
I Have ac, and it took me 3 hours to do mine. Luckily I had a friend helping drink my beer to help hold it up while I screwed it back together. In the mix I had my 3 year old boy helping, and that was worth a hour alone.
Ziegelsteinfaust is offline   Reply With Quote
coolant, heat, heater, heater core
