Old 03-21-2013, 12:02 PM   #1
99_Sierra
99_Sierra's Avatar
Will my 4l60e fit my 6.0
I have a 99 gmc Sierra 5.3 it has a 4l60e. I am building a lq4 out of a 2001 Denali. Will my 4l60e bolt right up to my 6.0?
99_Sierra is offline   Reply With Quote
Old 03-21-2013, 05:12 PM   #2
MadManAndrew
Re: Will my 4l60e fit my 6.0
It will bolt up but it won't last very long.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 03-21-2013, 05:30 PM   #3
99_Sierra
99_Sierra's Avatar
Why do u say that?? Reason I ask is his truck has a 4l60e and it has like 200k miles so his has lasted.
Old 03-21-2013, 07:47 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
Didn't the 6.0L come backed with the 4L80E.
If that's the case think of it like a 327 or 350 being backed by a TH350 and a 454 backed by a TH400.... or 4.8 and 4.5 with 4L60 and 6.0L with 4L80.
Some good info here:
http://www.gm-trucks.com/forums/topi...t-the-lq4-60l/
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-22-2013, 01:08 AM   #5
Sooner84
Sooner84's Avatar
I would definitely put a 80e behind it. I wouldn't even mess with building the 60e to hold up to a 6.0.
1984 chevy swb(1st truck, sold..)
2001 RCSB silverado, 5.3 with a little extra
2004 ECSB Silverado LT, 5.3 cam & bolt ons, 4l60e shift kit/stall, g80 & 3.73s
My first (1984 c10) Build
Sooner84 is offline   Reply With Quote
Old 03-22-2013, 06:59 AM   #6
low69chevy
low69chevy's Avatar
It will bolt right up I like to use my old flywheel when I do swaps and just make sure if your using one of the older 6.0s if it has the spacer between the crank and flywheel take it out. As far as the built 60 i've gone thru 3 and mine has all the goofies on it pi multi disc converter,trans cooler w/fan right now its getting rebuilt case it was starting to go out again so I recommend if.you can swap to a good 80e its worth it if you plan on beating on it, my 6.0 has cam/heads, fbo,nnbs intake and pretty much a whole bunch of goodies.
low69chevy is offline   Reply With Quote
Old 03-22-2013, 07:06 PM   #7
clinebarger
All 6.0L LQ9 & LQ4 that were installed in 1/2 ton chassis had either a 4L60E or 4L65E. A well built 4L60E can EASILY handle a cam/heads 6.0L...Where a stock 4L80E will handle it.
clinebarger is offline   Reply With Quote
Old 03-22-2013, 09:53 PM   #8
hotrodchevy1999
Hotrodchevy
hotrodchevy1999's Avatar
would a 4l80 out of a 98 chevy 2500 model work
2017 1500 CREW CAB GMC
1997 C1500 Chevy
1971 CHEVY CHEVELLE SS 402BB :
1971 CHEVY C10 Stepside Project 71 cluncker http://67-72chevytrucks.com/vboard/s...ferrerid=89816
My Build Second Chance Suburban (SCS)http://67-72chevytrucks.com/vboard/s...d.php?t=424650
hotrodchevy1999 is offline   Reply With Quote
Old 03-23-2013, 07:07 PM   #9
bighaas79
Wasn't there a good bit of torque management programmed into these trucks though? Even with the 4l80e there was torque management programming. Not saying it wouldn't work but there might have been a programming difference to help make the 60/65 last longer behind the 6.0.
bighaas79 is offline   Reply With Quote
Old 03-23-2013, 07:54 PM   #10
67ChevyRedneck
I'm sure there was too. Even the 5.3 is held back quite a bit.
Jesse James
Project "On a Dime"
Old 03-23-2013, 09:28 PM   #11
clinebarger
Yes, It will work. Non LS 4L80E's don't have the top center bellhousing bolt.
Different programming for sure, A LQ9/4L65E from a Cadillac Escalade will have different tuning than a LQ9/4L65E from a Silverado SS, Any 60/65/70 will need to be BUILT to handle a modified engine & or tuning.
Old 06-12-2018, 06:21 PM   #12
RedRider
RedRider's Avatar
Reviving an old thread here questioning my thoughts of running a 6.0L/4L60e combo in my 70 C10. I have the tranny in my garage with plans to do a 5.3 LS swap, then found a better deal on an LQ4. Lot's of opinions saying a 4L60e would hold up fine, and even more saying not a chance.
Seems to me that if GM didn't put the 4L60e behind the 6.0L neither should I, or am I just not adventurous enough?
1970 C-10 "Old Yeller"
RedRider is offline   Reply With Quote
Old 06-12-2018, 06:47 PM   #13
faribran
GM DID put the 4l65e behind the 6.0 ...and this is basically the same tranny
faribran is offline   Reply With Quote
Old 06-12-2018, 06:49 PM   #14
faribran
See earlier comment from Clinebarger. He knows his stuff
Old 06-12-2018, 06:55 PM   #15
faribran
We all know the drivers right foot can tear up most anything. The life of tranny will hinge largely on how it is driven and how well serviced\maintained.
Old 06-13-2018, 12:44 AM   #16
RedRider
RedRider's Avatar
So if it boils down to building a performance 4L60e vs finding a stock 4L80e, i’d probably go with the latter .
