truck is leaking
hey guys my truck has a small leak and when it rains it tends to drip off the emergency brake pedal on to my leg. it even does it when its sitting still and driving so i feel like its coming from up tom somewhere. is this common or a quick fix? i havent even looked into it yet i just wanted to see if there was something to look for when i do.
Jeremy '86 GMC 1500 dropped 6" in the front and 6" in the rear 2003 Land Rover Discovery Low Life |
Re: truck is leaking
Get the water hose and a flashlight out on a clear day, and you'll likely be able to find your leak. All I can say is get it done fast, those kinds of leaks ruin interiors really darn quick if not addressed quickly. Carpet goes bad, inside starts to stink, etc.
i had same thing type of leak,it was windshield gasket leaking.i had glass shop fix it.
78K & 79C Jimmys
hope it's that ,my 87 was ....rusted bad under the hinge seal,and side
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
X2 on the gasket. Its an easy fix. Just inspect for rust around the windshield perimeter. If you find some fix it. Good luck.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
Tags |
cab, leak, water |
