Old 04-08-2013, 03:39 PM   #1
lghell
NP205 shift rod
Started to clean my NP205 today and I saw that something was welded to the shift rod.
The transfer case shifts as it should so my question is why is that thing(to the right) welded to the shift rod?
/Patrik
C20 4x4 1970 TBI350/TH350/NP205
Sweden
lghell is offline   Reply With Quote
Old 04-08-2013, 03:58 PM   #2
Redcap
Re: NP205 shift rod
Because someone bubba'd that T-case.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 04-08-2013, 04:03 PM   #3
jjzepplin
jjzepplin's Avatar
Re: NP205 shift rod
I have two just like that. I think it is so that shift rail doesn't move back in without the other one moving. You see what I mean. If you pushed it from the right side only both would go in. Anyway= I think if GM put it there-leave it there.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-08-2013, 04:03 PM   #4
lghell
Re: NP205 shift rod
ok thx
/Patrik
Sweden
Old 04-08-2013, 08:56 PM   #5
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: NP205 shift rod
Exactly, I’ve seen several 205’s just like that. I think they were early '69 or '70’s with the short shifter rail on the passengers side. Check this out. Scroll down the page and read all about it.
DirtyLarry is offline   Reply With Quote
Old 08-17-2023, 05:07 PM   #6
wazzabie
Re: NP205 shift rod
I have a 71 np205 case and it looks just like this with the welded shift rod. It is welded from the factory.
wazzabie is offline   Reply With Quote
Old 08-18-2023, 10:17 AM   #7
jeffahart
jeffahart's Avatar
Re: NP205 shift rod
Yes, about your year and older the rails were the same length and they had the funky beatup/welded end. New ones have one longer rail and an offset linkage(not the flat straight one). Do a google for np205 shift rail linkage and you will see the offset linkage with a one longer rail. Bottom line, if you're casing down new rails, make sure you get the correct ones for your linkage... else prepare to modify your linkage.
j
White K20
jeffahart is offline   Reply With Quote
