Old 04-17-2013, 01:56 PM   #1
47twoton
47twoton's Avatar
Has anyone put a 454 in a 1947 2-ton?
Hello fellow builders,
We've recently acquired a rustic '47 grain truck...a two ton model with a 231 upgrade somewhere along the timeline. Hoping to shoehorn in a 7.4L to put her back to work. 4L80e and BBC courtesy of a 1992 RV with 60k miles. Wondering if anyone has advice on this swap and/or photos, measurements, caveats, etc.
Many thanks!
47twoton
47twoton is offline   Reply With Quote
Old 04-17-2013, 02:12 PM   #2
Truck Guy99
Re: Has anyone put a 454 in a 1947 2-ton?
My advice would be to box that frame. That engine was cranking out 105 hp at BEST when it was new. Now your stuffing in a big block with about double the horses? I would either box the frame of use the rv frame and do a body swap. If this is going on a highway much, you may want to swap out the axles for better brakes and gears. Just remember though, THIS IS WORTHLESS WITHOUT PICTURES!!!!
Truck Guy99 is offline   Reply With Quote
Old 04-17-2013, 03:36 PM   #3
Luther Grimace
Luther Grimace's Avatar
What TruckGuy said about the brakes is good advice. I'm trying to remember where I saw someone putting a Big Block in an old farm truck. I'll look for it. The frame on the 1 tons and up was a thicker and taller I believe? Probably be more apt to take the abuse. Can't wait to see pictures.
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 04-17-2013, 09:08 PM   #4
47twoton
47twoton's Avatar
Thanks for the replies Truck Guy and Luther G. You're right about the photos...worth a lot. Have yet to see any from a similar build, so would be of great value to me at this point. It looks really tight up front but if a 350 will fit, the 454 may have enough room too. I'll definitely post photos once some progress is made. Should be an interesting project.
Old 04-18-2013, 12:08 PM   #5
Truck Guy99
Pics or it never happened.
Old 04-18-2013, 12:31 PM   #6
YahamaR1
YahamaR1's Avatar
Its not a 2 ton, but a 454 will fit..[IMG][/IMG]
[IMG][/IMG]
YahamaR1 is offline   Reply With Quote
Old 04-18-2013, 01:52 PM   #7
buggy5872
buggy5872's Avatar
You might want to look into swaping out the heads on that 92 454. those were the worst big block heads gm ever produced. A good up grade is the 96-99 454 vortec heads. I did it on a 91 I had and it made a huge difference.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 04-18-2013, 01:55 PM   #8
YahamaR1
YahamaR1's Avatar
What is the problem with this heads,?
The engine runs good..
1947, 2 ton, 2-ton, 7.4l swap, engine swap 454
