Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 04-26-2013, 12:51 PM   #1
83cutlass
will a 383 crank fit in my 88' silverado?
Im wanting to build a stroker out of my 350 tbi and im wondering if someone can tell me if a 383 crank will fit without a lot of work? Any info or advice would be greatly appreciated.
83cutlass is offline   Reply With Quote
Old 04-26-2013, 12:55 PM   #2
vegadesign
vegadesign's Avatar
Re: will a 383 crank fit in my 88' silverado?
400 crank in a 350 = 383
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 04-26-2013, 12:58 PM   #3
83cutlass
Well the crank im buying is already set up to go in a 350 but ive been told by a few people that it wont fit in a late 80's block for some reason. Only the 70's and early 80's. Is that true?
Old 04-26-2013, 01:08 PM   #4
vegadesign
vegadesign's Avatar
there were some mild design changes in the later v8's but that was all upper engine.
you should be fine\
the crank journals should all match.
what year is the crank out of i can look up the specs for crank and piston journals
Old 04-26-2013, 03:49 PM   #5
83cutlass
Im not sure on specs ill have to ask. Im getting it off craigslist from a guy. I appreciate your help tho. Will I be able to keep my rods or get longer ones possibly? And would I be able to use the tbi still since the computer is set for factory settings or would I be better off getting a different intake and using a carb?
Old 04-29-2013, 01:55 PM   #6
83cutlass
The crank came out of a 76 and thats all I was able to figure out about it but I believe it will work. Im getting a set of pistons next weekend but I was wondering if someone could tell me what the max size rods ill be able to use and what size pistons would work with them I know ill need an offset pin location to use bigger rods. But would it be better to just get shorter rods since that means less weight and more durability? Im just tryin to get some ideas on how to do this easiest and with a budget. Any advice would be greatly appreciated.
Old 04-29-2013, 04:29 PM   #7
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
You're gonna have to do some machine work on the bottom of the cylinders for the connecting rods to clear. Best to take the block and all internals (pistons,rings,rods,bearings & crank) to have them do it right for you.
As for using the tbi set up, contact www.tbichips.com and get them to burn a new chip for your computer.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 04-30-2013, 09:17 PM   #8
benoit454
Chris
benoit454's Avatar
70's and early 80's crank won't fit an 86 and newer block, reason being 1 piece rms seal vs 2 piece, pre 86 was 2 piece and 86 and newer is 1 piece.
not sure if you can covert a 1 piece block to 2 piece or not.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 04-30-2013, 10:52 PM   #9
83cutlass
I actually just got done tearing it apart and ran into that problem. Is there any 400 cranks that will have a o e piece rear seal or possibly a 383 crank that would accept a one piece rear seal?
Old 05-02-2013, 05:50 PM   #10
benoit454
Chris
benoit454's Avatar
aftermarket like summit eagle etc have 383 or 400 cranks for a 1 piece rms.
I think northern auto parts has a vortec 383 kit, not sure if it'd work on yours or not being it's for a vortec which is 96 or so and newer, but 86 and newer is 1 piece, main difference is the heads and intake in the vortec blocks.
Chris
GIT R DONE!!!!!!
Old 05-07-2013, 06:59 AM   #11
BigBlocksRule
83cutlass, pm or email me, I have one on the shelf for a 1-pc RMS that I'm not going to use. It's new, never used, I'll sell it for less than the best price you can find.
BigBlocksRule is offline   Reply With Quote
Old 05-07-2013, 10:38 AM   #12
83cutlass
Im not sure how to pm on here but my number is 4173857875 if u wanna text or call. I work til 430 though. Id appreciate that a lot, I was about to just buy a stock one and put it back together.
Old 05-16-2013, 10:52 AM   #13
83cutlass
looking for parts for my 88' silverado 383 build with 1 pc rms
Hi guys I am looking for intake, carb, .040 or .060 over pistons, bearings, 5.7 inch rods.., mainly everything but the crank , cam, and timing chain. Im looking to build on as much of a budget as possible so please feel free to let me know what you have with a price offer. Thank you for youre time and consideration.
Old 05-22-2013, 04:33 PM   #14
beaugranbois
Don't know if you watch the Powerblock on SpikeTV but they did a budget build of a 383 over the last two weeks. Here's a link to the first episode. They pretty detailed on how they do it.
http://www.powerblocktv.com/episodes...3-stroker-pt-1
beaugranbois is offline   Reply With Quote
Old 05-24-2013, 07:53 PM   #15
benoit454
Chris
benoit454's Avatar
summit racing, jegs , northern auto parts, and speedway motors, cheapest places i found for parts.
Chris
GIT R DONE!!!!!!
