Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-27-2013, 02:22 PM   #1
Benji
Just Breathe
Well i figured that i should start my build thread. My first k5 and also my first rebuild.... Going to be a very slow build i feel. I bought the blazer in troy, ohio. It came with brand new rebuilt 350 with cam and flat head pistons. New rims and tires and some of the po's small stockpile.
Benji is offline   Reply With Quote
Old 05-27-2013, 02:43 PM   #2
Benji
Just Breathe
some pics
Old 05-27-2013, 02:54 PM   #3
Benji
Re: Just Breathe
a few more
Old 05-27-2013, 06:12 PM   #4
Rust_phoenix
Rust_phoenix's Avatar
Re: Just Breathe
Welcome, looks like a nice solid start, appears to have some upgrades added, i will be watching this one.
My build: Project "Lazarus" 8.1 Vortec and Allison in a 72 swb k10
http://67-72chevytrucks.com/vboard/s...d.php?t=555878
Rust_phoenix is offline   Reply With Quote
Old 06-28-2013, 08:34 PM   #5
Benji
Re: Just Breathe
Trying to catch up on posting. Bought blazer last summer. I've pulled body off and por 15 the underbody. Pulled motor for a rattle can paint job. Put new shocks and breaklines in. The trans worked when test drove at seller then I get home and it wasn't shifting. Had it rebuilt. On a good note I scored a hatch for 200 bucks.
Old 06-28-2013, 08:47 PM   #6
Benji
Re: Just Breathe
I installed the motor and trans. Then I blasted the firewall and had my brother paint it satin black. Put a 3inch body lift on with new body mounts. I quit for the winter due to no warm place to work on it. Now I'm working on the core support
Old 08-11-2013, 12:21 AM   #7
Benji
Re: Just Breathe
Got my core support and wheel Wells back from painter. The before.
Old 08-11-2013, 12:23 AM   #8
Benji
Re: Just Breathe
And after
Old 08-11-2013, 09:31 AM   #9
my90k5
72 K/5 Junkie
my90k5's Avatar
Re: Just Breathe
Lookin good!
72 k/5 CST 350 SM465 NP205
My Build Progress
my90k5 is offline   Reply With Quote
Old 08-11-2013, 01:37 PM   #10
Benji
Talking Re: Just Breathe
Im pretty sure those werent stock light buckets
Old 04-12-2014, 12:30 AM   #11
Benji
Re: Just Breathe
Well its finally getting warm out in ohio so that means i need to finish some honey-do lists and im able to get back to the blazer! I'm needing some opinions on the best way to tackle this body work. The passenger side, from what i can tell, is stock rocker. The previous owner cut both torsion boxes, made homemaid inner rockers and put new drivers rocker too high. I am also aiming to use the new blazer bedsides as what i see that is covered up is rough looking. My plan was to...
1. cut drivers outer rocker out.
2. try to get door to b piller gaps good by using come along to flex a piller straight due to no support from torsion boxes.
3. fab up support from a piller to b piller for both sides.
4. start on drivers floor, inner rocker, then torsion box
5. passenger side floor, inner rocker, then torsion box
6. both bedsides
7. outer rockers
8. doors
I know this will probably take years for me more than likely but i want to do this easiest and also the right way.
