Old 06-20-2013, 11:10 AM   #1
rfmaster
rfmaster's Avatar
Bearing Clearance
This an age old question - how much bearing clearance should you run in street driven 350 SBC. One common recommendation is:
Rod bearings 0.0020 - 0.0025" , side clearance 0.010 - 0.020"
Main bearings 0.0020 - 0.0030"
Crankshaft end play 0.005 - 0.007 crankshaft end play
I am in a process of putting a budget 350 (880 block, 1peice RMS)
Micrometer: Mitutoyo 103-217 (2 to 3", 0.0001 resolution)
Bearings: King Bearing 557SI (STD and -001)
Mains Measured Plasti-Gauge Plasti-Gauge
103-217 | STD | -001
M1: 2.4500 | 0.002 | n/a
M2: 2.4495 | 0.003 | 0.002
M3: 2.4495 | 0.003 | 0.002
M4: 2.4495 | 0.003 | 0.002
M5: 2.4490 | 0.003+ | 0.002 to 0.0015 (Probably 0.0018)
Rods
R1/2 2.0995 TBD (to be determined)
R3/4 2.0995
R5/6 2.0995
R7/8 2.0995
Crank thrust movement: 0.005 to 0.007 depending how hard I pry my bar
So I am going with mix set of main bearings - on the mains I am keeping #1 STD and 2 through 5 -0.001" based on platigauge indication. My only concern that #5 Main is a bit on tight side:0.0018"
Comments regarding #5 being a bit tight....
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 06-20-2013, 02:47 PM   #2
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Bearing Clearance
Was there any machine work done? Was the crank turned or polished? Block line honed? ....or are you just replacing the bearings?
prostreetC-10 is offline   Reply With Quote
Old 06-20-2013, 04:02 PM   #3
rfmaster
rfmaster's Avatar
Crank was polished (it was not turned) - it had 140k on it when I yanked it in favor of 3.75" stroker.
Block probably was line honed at one time or another. Crank turns very nicely with bearings configured in original post. It is a budget build - just tossing new bearings and rings and put it back into service.
//RF
"The Beast"
Old 06-20-2013, 08:36 PM   #4
manimal
manimal's Avatar
#5 is the thrust bearing right? .0018 is too tight. I always set that one at .0025-.003
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 06-21-2013, 07:45 PM   #5
crazy longhorn
Fabricate till you "puke"
Yup, I would run a tad looser on the thrust main also. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-23-2013, 01:11 PM   #6
GRX
GRX's Avatar
^^ not only that, #5 gets the full flow of oil then sends it on down the line/s. Otherwise clearances look good. You are installing a new pump right? Std volume with high pressure spring.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 06-23-2013, 03:39 PM   #7
LONGHAIR
If you are that concerned about it being too loose with the standard bearing and too tight with the -.001 bearing, have the machine shop polish it a little more.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-23-2013, 05:00 PM   #8
bobs86silv
bobs86silv's Avatar
Are you using any lubrication on the bearings or journal when you are measuring? Even a splash of any goo can give you a false reading. Rods are a bit trickier because you can easily distort the strip when you are taking the rod caps off. Is the crank nice and round? Is taper in check, or are you figuring from hi/average? A bit to the looser side will keep you out of danger, a bit on the tight side can get ugly fairly quick. Lots of science to bearing load and oil film, but SBC is somewhat forgiving on clearances.
Good luck! Robert
86 Silverado SWB 350/350/3.08 9.7-1 Forged pistons Eagle Rods Eagle Crank Zero Deck Balanced Blueprinted 180cc DART Heads Roller Rockers RPM Intake Demon Carb Flowtech Headers 400HP/400TQ
bobs86silv is offline   Reply With Quote
bearing, clerance, main
