Old 06-22-2013, 01:34 PM   #1
wittyandnitty
starter will not turn but all other electronics do.
I started the truck for about 5 times since I put in the new starter then out of the blue the starter was not turning at all. Dead silent. But the gauges,lights and everything does. Help on any solutions
1981 Chevy C10 Shortbed Stepside
350 Edelbrock 1405 carb, true dual exhaust
HEI
wittyandnitty is offline   Reply With Quote
Old 06-22-2013, 02:46 PM   #2
Car'n'Guitars
Car'n'Guitars's Avatar
Re: starter will not turn but all other electronics do.
Starter solenoid would be my guess.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 06-22-2013, 02:53 PM   #3
wittyandnitty
I hope not because it is a new starter that I got 3 weeks ago
HEI
Old 06-22-2013, 02:54 PM   #4
wittyandnitty
It started fine a couple hours ago
HEI
Old 06-22-2013, 06:04 PM   #5
Sodell
Sodell's Avatar
Make sure everything is hooked up correctly, check and make sure the nuts are tight on the starter.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 06-22-2013, 06:33 PM   #6
Jonboy
Slots go on anything!
double check the grounds as well.
Old 06-22-2013, 06:33 PM   #7
Car'n'Guitars
When we changed the starter in my Mom's Kia we got 3 brand new starters from Auto Zone that were junk out of the box, so it is possible.
Old 06-24-2013, 11:28 PM   #8
wittyandnitty
What grounds the starter? Or little more specific?
HEI
Old 06-25-2013, 09:36 AM   #9
Jonboy
I would check them all. Frame to block, battery to frame, cab to block. You could also pull the starter and have it checked. Could be bad.
no start, starter, was great before
