Old 07-08-2013, 06:04 PM   #1
RoughKuntry
RoughKuntry's Avatar
Arrow Need help on Rear Axle? Don't know what it is.
I have a 1973 GMC 25 Hundred Super Custom. I know it says 3/4 ton truck but here's the problem the Rear Axle supports a 5th wheel hitch in the back of the bed. I will post pictures, I have the rear axle manufacture numbers but that's it. It has an 11.24 Drum, And napa still can't figure out what it is. Can I get some help guys? Its a 14 bolt. I though it looked like a 1 ton Single rear end. But I could be wrong.
RoughKuntry
73 GMC 25 HUNDRED :Sold
79 GMC High Sierra 4x4 (Ma-Duece) :Sold
99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling
88 Chevrolet Burban 2500 4x4 :Buying
RoughKuntry is offline   Reply With Quote
Old 07-08-2013, 06:44 PM   #2
b454rat
Re: Need help on Rear Axle? Don't know what it is.
3/4 and 1 ton are pretty much the same rear, just the 1 ton has bigger breaks. I believe 11" or 13" are the options for breaks...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 07-08-2013, 10:22 PM   #3
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
The one tons had 2.75? x 12" & 3.5" x 13"
If it has the 11" brakes odds are it is a 3/4 ton rear. you can also tell by the spring plate mounts the 1 ton is different then the 3/4 ton. But other then that they are the same.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 07-12-2013, 02:20 PM   #4
RoughKuntry
found out that the rear is a Heavy Duty 3/4 ton. And the parts store still thinks that 1 ton break shoes will fit it. :/ So I called up the NAPA store and they had my parts ready this morning. so you all might get better pictures of the new truck soon
-Jeff
RoughKuntry
axles, swapped
