Dual compressor and tank plumbing. Which option (pic inside)
I ordered a kit off slam specialties and I'm trying to figure out how to plumb the tanks from the compressor. There were no instructions with the kit so I laid everything out and got it some what figured out with the exception of how to run the compressors.
Which option will function best? Option 1: One compressor per tank ![]() Option 2: Both compressor to one tank ![]() These are the bags of fitting they sent and labeled. ![]() ![]() ![]() ![]() ![]() ![]()
Sin7 = Luis 1959 Apache |
Re: Dual compressor and tank plumbing. Which option (pic inside)
This is my first bag setup by the way. It's been a great learning experience.
Pics of the truck being bagged. 64' F100 (I know I know..its a ford, but my daily driver is a chevy). I put a jaguar clip on the F100. ![]() ![]()
With your tanks tied together, it shouldn't matter since the compressors will just see it as one large tank. As long as you monitor the tank pressure and have a pressure switch in the system, the only difference between one tanks and two is volume.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
That was too simple. I guess I was thinking too hard about it.
Yep, looks good either way you do it. Just make sure you have a drain on the tank that has a compressor(s) going into it. Also would recommend a safety valve in the system, to protect the compressor if the safety valve should fail. On a 150 PSI system, you would want a 175 PSI safety blow off valve. We have them if you need them.
Travis Posted via Mobile Device |
I tend to say that a lot.
Champagne Taste on Beer Budget
And here I thought I was the only one around that thought like that.
![]() btw very nice setup Sin7, good luck with it!
Coming Soon: Project 1970 Country Truck |
