Old 07-11-2013, 09:52 AM   #1
Bregion
1962 gmc rearend swap?
Whats the easiest rearend to swap out for my old one off my 62 GMC? I dont care much about gear ratio. Just want 5 lugs instead of the 6. I dont have the option of redrilling. So looking for a newer year chevy to just swap out. What year should i go with?
Bregion is offline   Reply With Quote
Old 07-11-2013, 10:48 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 1962 gmc rearend swap?
73-87 12bolt I believe is your only option since 60-62 rears are wider than 63-72. you will need to weld on the trailing arm mount though...unless you have leaves now
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-11-2013, 01:45 PM   #3
Smo_King
Smo_King's Avatar
Is it a pretty straight swap if you have leaves? I have the 3spdOD tranny... Bed is off atm just curious if I can get in the 13>MPG range somehow.
Smo_King is offline   Reply With Quote
Old 07-11-2013, 02:08 PM   #4
Bregion
It still has the coil spings in back. Leave springs came in 63 i think.(not sure). So do you think it would be better to weld a bracket on the rearend and us u bolts to the trailing arm?
Old 07-11-2013, 07:18 PM   #5
Brad54
Brad54's Avatar
That's a Dana 44 rear, right? (being a GMC).
If you end up taking it out, I sure would be interested in one of the axle shafts!
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 07-11-2013, 11:10 PM   #6
Bregion
Not sure what they are but willing to get with you and sell one to you if its what ya need. You want my number?
Old 07-12-2013, 02:20 AM   #7
Captainfab
60-66 Nut
The '60 to early '70 1/2 ton pickup differentials are all 62" wide. The late '70-'87 1/2 ton differentials are 63.5" wide. So that will be .750" wider on each side. The '71-'87 differentials are the 5 x 5 wheel stud pattern. To install one under your '62, you will need to cut off the leaf spring perches, and the shock mounts. Then you will have to weld on the trailing arm mounts, and transfer the panhard bar mount from your Eaton HO32 currently under your truck. In doing this, you will want to be sure to get your pinion angle where it needs to be. Use your current differential for a reference.
Old 07-12-2013, 02:18 PM   #8
Bregion
Any recomindation on the year i should go with? Im hitn up the junk yard. Are all they chevys gonna have the same yearend in those years?
Old 07-12-2013, 02:29 PM   #9
McCoyAZ
McCoyAZ's Avatar
Do what I am doing.
Yank those axels out, have a machine shop remove the wheel studs and re drill it to a 5 lug. Buy a pair of 71 rear drums 11" x 2" and new studs and replace the axel bearings and be happy.
McCoyAZ is offline   Reply With Quote
Old 07-12-2013, 02:59 PM   #10
slepysal
slepysal's Avatar
I hope to swap the 67 rearend that has 5 lug axles in it soon. I have the new axle pads, adjustable trac arm, ujoint, lowering springs and new spring hardware. As well as new wheel cylinders and brake hose. All that is missing is a welder
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 07-13-2013, 12:31 AM   #11
Captainfab
60-66 Nut
The '63-'82 C10's had the 12 bolt. The '80-'87's had the 8.5" 10 bolt. There were a couple years of overlap there. Either one should work just fine in your truck. If you have a choice, I would get one that has the 11" x 2.750" brakes instead of the 11" x 2" brakes.
1962 chevy, 5 lug, rearend
