Old 07-12-2013, 09:35 PM   #1
Bowed
That transfer case boot
I have a 2000 Silverado K1500 with the auto transfer case . It has a small leak at the front of the case in the area of the front propeller shaft . There is a boot ( picture ) with one clamp. On line info says , some cases had one clamp and other cases had two clamps . I think this must be the two clamp boot and the first clamp is missing . Am I right and is the boot my most likely candidate for the leak ? Thanks .
Bowed is offline   Reply With Quote
Old 07-13-2013, 01:57 PM   #2
biggsteve97
Re: That transfer case boot
That boot is just a dust boot to keep the shaft from getting to dirty and tearing up the seal in the front of the t-case where the yoke slides into the case. Most likely your leak is from a worn front output seal.
Thank a Veteran. They have sacrificed more than you will ever know!
2003 Chevy Z71 Tahoe 190,500 miles
2002 Chevy Silverado 1500 4x4 230,000 miles
1987 custom built Silverado 4x4 435,764 miles
1985 K5 Blazer 396 bb 4x4 project
1982 K5 Blazer Silverado 4x4 519,348 miles
biggsteve97 is offline   Reply With Quote
Old 07-17-2013, 12:28 AM   #3
Bowed
Well then , time to take it apart I guess . Thanks BiggSteve.
