Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 07-21-2013, 05:54 PM   #1
egarage
46 Custom truck interiors
I am looking for ideas for customizing my truck interior. I don't like the metal strips that cover all the seams and the screws and I am looking for an alternative. Any ideas or pictures you may have would great.
egarage is offline   Reply With Quote
Old 01-12-2014, 09:20 PM   #2
gag1025
Re: 46 Custom truck interiors
I am close to doing my '53 Chevy truck interior. I am going to order a full headliner from Classic Parts. It is made from ABS plastic. I will cover it with fabric. ABS is pretty amazing stuff. You can heat it and form it. You can paint it or spray adhesive on it and use thin foam and fabric to cover it. I will use it to form up the area behind the seat as well as for the door frames. I plan on covering all the metal except for the dash.
gag1025 is offline   Reply With Quote
Old 01-15-2014, 10:23 AM   #3
egarage
Thanks Sounds good i will have to look into this. Don
Old 04-03-2014, 10:12 PM   #4
Wrecker55
Wrecker55's Avatar
just did mine, covered all the moulding with vinyl and used clips so you dont see all the screws.....fiberglassed 1 piece headliner and foamed and covered that to......made my own seat....all traditional style
Wrecker55 is offline   Reply With Quote
Old 04-04-2014, 01:07 PM   #5
egarage
Looks grate. I want to do the same to my seat but will have to let some one else do that because I could never do that. When you installed your front fenders, grill etc. did you put them all togeather and then install them on truck or did you install one at a time on the truck. This is all new to me and I try to ask questions as I go. I put a tci front end on mine and had some one else do all of the welding I also put in a 292 inline 6, 700r4, moved radiator inside radiator frame, camaro rear end and new floor pan. It takes me for ever to do these things becaues I do and redo every thing several times befor I get it the way I wan't it. I am also a retired contractor. Good luck on your build Don
Old 04-05-2014, 10:12 AM   #6
Wrecker55
Wrecker55's Avatar
no you need to assemble it on the truck, not like the later models that you can pull the whole doghouse off
Old 04-05-2014, 05:32 PM   #7
egarage
OK, Thanks I was just trying to figure out the best way to put it together.
Old 05-05-2014, 06:15 PM   #8
solidaxel
solidaxel's Avatar
Did you cover the stock door panels, or build new ones?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-05-2014, 06:31 PM   #9
gag1025
Actually I ordered an ABS headliner from one company (other than Classic Car Parts) and it did not fit. It was not the suppliers fault. The fault lies with the company who manufactured the part. I even called them and they were unwilling to take the part back even though they made it. Their reason was that I had bought it from someone else. The people they sold it to. Rod Doors in CA has the only parts for my '53 Chevy truck that will fit correctly (headliner, door panels and behind the seat panel). I am going to let my upholstery guy tell me what he is going to use and work it out with him. A lot of those guys use Luan plywood as well. I may end up getting a 4' x 8' piece of ABS for the rear (behind the seat) panel and use a one foot diameter round roll to form the curve using a heat gun. That is the beauty of ABS in that you can heat it up and form it. When it cools it stays in that shape.
1953 Chevy 3 Window Truck 3100 Series
