Old 07-31-2013, 09:47 PM   #1
1972BackInBlackC10
1972BackInBlackC10's Avatar
Arrow center console swap into 99 silverado reg cab
I want to put a center console into my 99 silverdo reg cab, I already know that the console uses the same mounting points as the jump seat but I was wondering do I need any of the parts from the dash like the section with the glove box door etc or can I just remove my cup holder and install the console using my existing dash?
1972BackInBlackC10 is offline   Reply With Quote
Old 08-01-2013, 10:14 AM   #2
thomas_a_reed
thomas_a_reed's Avatar
Re: center console swap into 99 silverado reg cab
A friend of mine just did this swap.. He had to change the the glove box section and the section under the wheel to to get his to work..
66 CHEVY STEPSIDE 2WD W/283 ( FAMILY HAND ME DOWN)
81 CHEVY SHORT BED 2WD W/250 4SPD TRANS STRAIGHT 6 ( CURRENTLY UNDER CONSTRUCTION)
01 SILVERADO SHORT BED 2WD W/4.3 5SPD TRANS ( DAILY DRIVER) Sold
03 SIERRA 4X4 STEP SIDE EXTRA CAB 5.3 AUTO( NEW DD)
09 CHEVY COBALT W2.2 AUTO (GF'S DAILY DRIVER)
thomas_a_reed is offline   Reply With Quote
Old 08-01-2013, 07:21 PM   #3
nxtlevl
nxtlevl's Avatar
All depends on what console you are using..If you are using a 99-02 console, then nothing needs to be done...If you are using a 03-06 console, then yes, you will need the lower dash pieces....I just did this swap in my regular cab 2000 a while back...I used a console from an '02, took out the cassette player that was in the console, and ordered a "pocket" to take it's place...
2000 Silverado RCSB..2/4 drop..20'' GM Accessory wheels...Cowl hood...blah,blah,blah.....
nxtlevl is offline   Reply With Quote
Old 08-02-2013, 12:21 AM   #4
1972BackInBlackC10
I got this message a lil late lol I got all the pieces including the dash but that's ok I got it all for 60 bucks, need to order that pocket piece for the spot on the console the one I got had the cd player
