Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-15-2013, 07:45 PM   #1
stupidfish1
72 C-10 Engine wiring harness
Hi. I'm converting my 72' C-10 with an L6 to HEI. Done quite a bit of research online and decide to draw my constant 12 volts from the "keyed" port where my original resistance wire was located. Removed the wiring harness, cleaned and removed unnecessary wiring and traced the original resistance wire back to the harness block.
It is piggybacked to a 8-10ga. wire running to my choke solenoid? This piggy back was obviously done either professionally or factory. I've never seen this on any schematic? Seems like a lot of current to put another 12-14 gauge wire on here to supply the new distributor?
Any suggestions would be greatly appreciated.
I would like to keep this install relatively "clean" that's why I decided on this port rather than going to one of the non fused ignition tabs on the fuse block.
Thanks in advance, Steve H.
stupidfish1 is offline   Reply With Quote
Old 08-15-2013, 11:16 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 72 C-10 Engine wiring harness
Hi Steve and welcome to the forum.
I never recommend tapping anything off the distributor wire, especially an HEI. I know a lot of guys do it for the choke coil. A 16 gauge wire is plenty big for the choke coil and 8 to 10 is ridiculous.
Any key on hot wire such as the wiper yellow wire or the heater fan switch wire., or the brown accessory wire would be good with a 10 amp fuse inline.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-16-2013, 12:13 AM   #3
stupidfish1
Hey VetteVet, Thanks for your response and may I say thanks for your service. I've read many of your posts. I understand what your saying about tapping but, would you recommend running the distributor off of this "port" which is supplied by a constant & crankinig 12 ga. 12v. supply and run the choke coil off of another "keyed" 12v. power supply. I'm no expert when it comes to this stuff.
This is my son's first vehicle and, I've spent some time over the years turning wrenches but ELECTRICITY boggles me.
I'm not kidding when I describe the diameter of this choke coil wire. It's over 1/8th of an inch wide including insulation-almost 3/16ths.
If I'm misunderstanding something I apologize.
Thanks again, Steve H.
electric choke, hei conversion, wiring harness
