Old 08-16-2013, 06:35 PM   #1
thebluegoose
Exclamation What do i need to do to put a cd player in my 68?
do i need any special wiring harnesses? if so can some body please tell me which one? One more question my radio is getting power but im not getting any sound out of it i have no antenna could that be the problem? i figured i would at least get some static noises
thebluegoose is offline   Reply With Quote
Old 08-16-2013, 06:44 PM   #2
buddha823
Re: What do i need to do to put a cd player in my 68?
You need a constant power (red) acc power (yellow) ground (black) then the rest will be speakers
buddha823 is offline   Reply With Quote
Old 08-16-2013, 07:01 PM   #3
thebluegoose
do you know of any on the internet i can buy?
Old 08-16-2013, 07:03 PM   #4
buddha823
Not off hand to clip on factory .... I myself just ran all new to everything
Old 08-16-2013, 07:07 PM   #5
thebluegoose
ok thank you, ill keep searching the net for a factory one
Old 08-16-2013, 07:46 PM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: What do i need to do to put a cd player in my 68?
Checkout Cruitchfield if anybody has it they will.
On our old trucks all it was was a hot and ground with speaker wires.
New radio's have constant hot for the memory a switched hot and ground then speaker wires. Blue will be for a electric anntena are for a amp.
U could go to radio shack and buy a multi connector for all of it and solder it all together if u wanted to.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-16-2013, 08:01 PM   #7
thebluegoose
thanks man thats not a bad idea
Old 08-16-2013, 08:03 PM   #8
thebluegoose
checked cruitchfeild, i tried to search for a 68 c10 and they dont have it on their drop bar
cd player, radio stereo wiring, wiring harness
