Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 08-26-2013, 12:22 AM   #1
ChevyGuy98
Dad's 07 classic Sierra having problems
His truck has a 6.6 Diesel engine and it randomly turns off and then he has to pump something to get it running again. What is going with the truck?
ChevyGuy98 is offline   Reply With Quote
Old 09-14-2013, 06:39 PM   #2
sleepertruck72
sleepertruck72's Avatar
Re: Dad's 07 classic Sierra having problems
Sounds like he is getting air in the fuel line. Is he pumping the prime pump at the fuel filter housing ? There is a vent screw that needs to be opened while doing so until the fuel comes out without air... then tighten the screw. It is common for the o-rings to wear out at the fuel lines causing air to be sucked in (I have been told this but never actually replaced them)
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 09-15-2013, 03:49 PM   #3
ChevyGuy98
Yeah he has to pump it everytime. Anyways I'll check it out thank you for the information.
Old 09-15-2013, 07:14 PM   #4
clinebarger
Rebuild the fuel filter head First! http://nicktane.com/osc/product_info...59fbb19a7cba4f
I'm guessing this is a GMT800 truck with an LBZ?
clinebarger is offline   Reply With Quote
Old 11-13-2013, 09:46 PM   #5
ChevyGuy98
He's just going to buy another engine. The engine has the pump problem and the injectors don't work and the transmission gave out too, but that can be fixed.
Old 11-13-2013, 11:47 PM   #6
clinebarger
This sounds very unlikely? The CP3, Injectors, & Trans failed????
Old 11-14-2013, 02:33 AM   #7
ChevyGuy98
Yes unless I heard wrong. However I know for sure that the injectors and the pump are no good. About the transmission whenever it shifted gear it hung back and the truck jerked forward suddenly every time, but i'll see what's going on.
